G.Skill Pi Series 17600 4GB Kit
3D Benchmarks
3D Benchmarking
All of our 3D tests were run at 1680x1050 with the settings maximised in game. Anti-aliasing is mentioned when applied.
3D Mark Vantage
Anyone who has read my reviews for a while now will know I'm not the biggest fan of the 3D Mark suite of programs. Unlike the excellent PC Mark the results bear almost no relation to any game I've ever come across. Nonetheless it's as big a part of hardware reviews as the text. In fact some people would probably be happy just getting a p-score and not reading anything else.
Anyway, here is the result with the score difference being within the margin for error. This G.Skill RAM certainly is impressive so far, but not here. So let's move on.
Modern Warfare 2
With the system being identical to the setup we used for the Maximus III Extreme tests we've included the Trident DDR3 1333 results from those tests here because we know that most people use their PCs almost exclusively for gaming and if fans are to be won or lost it's in the ability of a piece of hardware to give those extra frames per second that really add something to a wanted list.
Firstly, wow. Ok the minimum doesn't change much but that's a CPU/GPU related thing, whereas the average and maximum results comprehensively backup the maxim that bigger, better, faster, more is something to strive for. The overclocked G.Skill Pi giving a result parallel to the 4GHz CPU run! Combine the two and minds indeed will be blown.
Crysis Warhead
Cryteks venerable old engine shows no signs of ever finding a computer able to run it properly and so it's always a great test of new hardware. The slightest increase in power gives a good end result.
Yet again we have a wonderful situation in that the extra speed the G.Skill Pi Series RAM gives us really makes a difference, and in its overclocked state it is sufficient extra grunt to give a result akin to the 4GHz test from the ASUS Maximus Extreme review. The best part of 3FPS from a 100MHz memory overclock is amazing, if not slightly perplexing given that it's about 50% of the performance increase 1GHz extra memory speed gave us over the Trident. The tests were run and re-run and the results are correct.
Dirt 2
The latest effort from Codemasters really shines in graphical and gameplay terms, and the engine itself provides good scaleability and performance on even low-end systems.
If our Crysis Warhead results were impressive, Dirt 2 shows an even more jaw-dropping improvement both over the G.Skill Trident RAM and the standard G.Skill Pi Series we're reviewing today.
The actual gaming results here nicely back up what I was saying about 3D Mark Vantage, with all of them showing a good improvement at all levels.
We've got the numbers, should you buy this?
«Prev 1 2 3 4 5 6 7 Next»
24-02-2010, 16:37:01
pazman4
Great review thanks. The reduced prices are realy tempting me to DDR3 now.Quote
24-02-2010, 21:26:16
Lallespasser
You stopped doing the The Good/The Mediocre/The Bad section?Quote
24-02-2010, 21:48:53
VonBlade
No, but the summation was sufficiently obvious that there isn't anything mediocre or bad. So I'm not going to add a section needlessly.
Thanks for the comment.Quote
24-02-2010, 22:21:01
JN
Great review dude. G.Skill are certainly making their presence in the UK known.Quote
25-02-2010, 08:09:54
Lallespasser
That was my guess too. Still such a section with just a blank bad and mediocre part just looks all the more awesome Quote
