Kingston HyperX Savage DDR3 2400MHz 16GB Kit Review
Latency
Latency
Latency is one of those curious things wherein the measurement used is so microscopic that the difference between the lowest latency, in this case the HyperX Predator, and the highest is negligible. Obviously we want low latency if possible, but you need to have a result of 80ns of above before even benchmarks will notice. With that said the HyperX tucks neatly into second place in our graph.
«Prev 1 2 3 4 5 6 Next»
15-12-2014, 13:07:55
Thelosouvlakia
N00b question, will those work with the 990FX chipset (provided that the board supports 2400Mhz DRAM speeds)?Quote
15-12-2014, 15:00:34
Boinkjumper
Hmm, it might only seem to support the following chipsets: H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets
as well as A75, A87, A88, A89, A78 and E35 AMD chipsetsQuote
15-12-2014, 15:20:06
NeverBackDown
You could easily google it and look at the compatibility list on the website...Quote
15-12-2014, 19:05:18
realneil
Great looking RAM, and as said in the review, the HyperX name means that it's good stuff. (worth the small price premium)Quote
16-12-2014, 06:42:02
Thelosouvlakia
Asus hasn't updated their Memory compatibility lists for those motherboards, neither Kingston has included the chipsets to the tests.. However if it supports E51 chipset, 990fx shouldn't be a problem, idkQuote
