OCZ Blade DDR3 PC3-16000 6GB Kit
3D & Gaming Benchmarks
3DMark is a popular synthetic gaming benchmark used by many gamers and overclockers to gauge the performance of their PC's. All 3DMark runs were performed a total of 5 times, with the highest and lowest results being removed and an average calculated from the remaining 3 results.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results conclusions
While reading the results above, consideration should be given to the fact the OCZ Blade kit was run with the CPU ever so slightly overclocked from a stock 2666MHz to 2717MHz. While this is hardly a dramatic increase, it is an increase nonetheless and should therefore be assessed while viewing the benchmarks results.
That said, the lead the OCZ kit has over the other kits on test is plain to see with the Blade 'Dominating' it's nearest opposition throughout the testing.
Let's head over to the conclusion...
«Prev 1 2 3 4 5 6 Next»
25-05-2009, 07:46:32
A very impressive kit there with some incredible bandwith figures, granted, at the price of a high end graphics card!
Excellent review w3bbo.Quote
25-05-2009, 07:53:31
This is the thing that bothers me about the cpu vS memory benching and testing.
A linked-to website, which has been a companion listing of all cpus in conditions, listing many hardcore intensive processing examples of how cpus compare to others ------- this qualifier out of the way.
On this listing, the comparisons of said cpus show no-difference in running memory kits in single/dual/tri arrangements when running the benches used - but appears to show 1 cpu triumphing over others and is accepted as "well that shows that these cpus are better than others".
Surely this is complete crap. Just as a starter, every1 will know that dual channel memory works more efficiently than single - that's a straight forward 64 bit vS 128 bit logical answer. Same as 2 disks in raid0 vS a single disk, as a loose example.
Now, if the cpu benches in the list are proving "it doesn't matter" - which is bollox imo, I'm sure the majority will agree, then surely the intensive hardcore professional benches they're using, the likes of video conversion, archive packing, are failing the test and the results are worthless.
These memory strips are obviously extremely good. The said site would have u believe that using 2 of these strips instead of 3 will have no-difference to professional apps being used on ur pc (which we have established is a load of crap).
Argument may be that the tests used are done in seconds where the differences in running various memory arrangements aren't appreciated - well that's crap too cos let's realize for a second that it's the 21st century, and although computers and software are moving at a snails-pace compared to the huge strides we would get in the past, these processes are actually done in seconds!
No account either of 12m cache vS 6m over periods - which makes a difference.
Awesome review, great set of memory, and two fingers to stoopid bench listing sites that people rely on to make points about "new tech".Quote
25-05-2009, 12:11:58
Looks some great RAM, bit pricey, but you get what you pay for I guess. 12GB might be a little pricey tho
Could you rerun that last far cry test because that overclock will obviosuly massively affect the results?Quote
25-05-2009, 13:43:13
Re run it in what way? You can't have DDR3 running at 2000MHz with the CPU at stock speed I'm afraid. It's either 2180 or 1866.Quote
25-05-2009, 13:50:25
Fantastic review mate and a scrummy looking piece of kit. Luff OCZ RAM (8GB myself )Quote
