Patriot 6GB DDR3 PC3-12800 1600MHz Viper Series Low Latency Kit
Memory Benchmarks
Published: 20th February 2009 | Source: Patriot | Price: £74.74 |
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Focusing mainly on software and hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining 3.
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
Results Observations
It seems the Corsair kit has certainly met its match. Outscoring our previous award winning kit in every benchmark bar one, the Patriot Viper snatches the performance crown from Corsair. Interestingly the Patriot kit was a little slow off the mark in the SuperPI 1m test but caught up with the 8m and 32m runs respectively.
Let's see how we got on with the run of 3D Benchmarks...
I love those heatsinks. Great RAM, smokes the Corsair in almost all the benchmarks
Quote
The gaming benches do show some seperation, the individual testings reflect to the contrary in the main.
Lose the big spike heat sinks, they aren't necessary afaik, the days of smoking ddr1 are long gone - and the big thing is they offend a fan for ur tower cpu cooler that rear-faces.
Price isn't as scary as I thought tbh.Quote
I liked the heatsinks tbh. While I wouldn't necessarily say they are a definite requirement, they did get warm to the touch so were obviously doing something. Having large heatsinks also does away with the requirement for a memory fan.Quote
U take a large amount of copper and put a current through it, it will raise it`s temp. Keeping the temp within the copper, i.e. putting a blue design over it, isn't going to disapate it anytime soon. Not even with a fan. U'r pretty much insulating it in.
U could get away with no sink, and allow a rear facing cpu fan.
Or reduce the fins, lose the blue insulation, and have a nice old style spreader if u wanted - and allow a rear facing cpu fan.
Either way, unless u insulate the heat within the devices, they aren't meant to get that hot these days I don't think.Quote
This looks like a pretty good kit, at an amazing price really. Nice thoroughly done review as always guys. Might consider these if I go i7 in the next 6 months...
Quote
