Visiting the Pro Gamers Group at CES 2026
AeroCool
AeroCool at CES 2026
At CES 2026, AeroCool had a big presence at the Pro Gamers Group booth, with new fans, CPU coolers, cases, and more. Above, we can see AeroCool’s new Forge series fans, which feature daisy-chaining support, new fluid dynamic bearings, and a new “copper ring design. Below, we can see that these new fans are integrated into the company’s new Icicle AL40 and AL60 Digi CPU coolers, which both feature real-time digital displays that can showcase important system information.
With these new CPU cooler models, Aerocool has highlighted higher-density fins, which complement the cooler’s improved Forge series fans.
Next, we have Aerocool’s new Premier G1 and Smart G1 power supplies. For those seeking greater affordability, the Smart G1’s non-modular design keeps costs down while maintaining a gold efficiency rating. The Premier G1 features a Cybenetics Platinum efficiency rating, modular cables, and a zero-RPM fan mode for low loads.
For CPU liquid cooling, Aerocool offers the Oasis V2 CPU cooler, available in 240mm and 360mm versions. These coolers support up to 260W and 300W TDPs, respectively. The unit’s fans and CPU block unit feature RGB lighting. Unlike many other AIO liquid coolers, Aerocool uses a pump integrated into its radiator, reportedly enabling higher efficiency.
Next up, we have AeroCool’s D520A and P500B Digi PC cases. Both are ATX power case designs that will be available this year. The P500B Digi includes a digital screen at the front/bottom of the case, while the D520A features a front mesh design that enables strong frontal airflow.
