ASUS U-75HA 750w ATX PSU
Published: 24th January 2009 | Source: ASUS | Price: N/A |
But why the reaction? Well, over the past few years there has been an undeniable increase in companies that have absolutely no previous experience in the PSU market jumping on the bandwagon. This has resulted in the market being flooded with PSU's, most of which are made in the same factories and all are fighting for a place on retailers shelves. Of course this isn't necessarily bad for the consumer as more competition often results in price wars and many bargains to be had, but from the side of the manufacturer such competition in an extremely crowded market can be crippling.
Of course, maybe I'm jumping the gun here. After all both OCZ and Corsair went from little more than a memory manufacturers to being some of the most preferred PSU manufacturers (in the UK at least) overnight. It's totally possible that a large name such as ASUS could do exactly the same. So with an open mind, let's take a look at the specifications listed on ASUS' website:
Equipped with four +12V rails, the U-75HA provides enhanced stability. Additionally, the U-75HA is certified with the 80 PLUS specification for great energy efficiency.
Energy-efficient
Certified with 80 PLUS specification (up to 86% efficiency)
Active PFC delivers environmentally friendly power with a high power factor (PF) of up to 99%
Stability
Accurate power rating delivers its full rated power
ATX12V Ver. 2.3 compliant-real four 12V rails provide stable support for high-end graphic cards
Dedicated power circuitry: delivers reliable output to delicate components
Ventilation
13.5 cm ball-bearing fan with auto thermal acoustics noise control
Cable sleeve improves internal airflow within the system.
Hexagon venting holes for efficient heat dissipation
Expandability
Provides both 6-pin and 8-pin PCI-Express connectors for future upgrade to graphic cards
Rich expandability with 6 SATA, 6 peripherals, 2 FDD, 4 PCI-E and 1 EPS connectors
EPS connector provided for dual CPU usage
Safety
Certified with CUS, Nemko, CE, BSMI, TUV, FCC, C-TICK
Protection: OVP, SCP, OCP, NLO, OTP, UVP, OPP
Model No. | Input Range | Output Voltage | Total Output | |||||||||
Input Voltage Range | Input Frequency Range |
| +3.3V | +5V | +12V1 | +12V2 | +12V3 | +12V4 | -12V | +5VSB | ||
U-75HA | 100~240Vac | 47~63Hz | Max. Load | 30A | 30A | 18A | 18A | 18A | 18A | 0.6A | 3.5A | 750W |
Max. Output | 160W | 648W | 7.2W | 17.5W | ||||||||
727.8W |
Starting with the basics, the U-75HA is certified as an 80Plus efficiency unit with ASUS claiming levels as high as 86%. Under the new 80Plus rating system this effectively certifies the unit as an 80Plus Bronze PSU, with Silver certification just 2% out of its reach (providing the unit can deliver its 86% efficiency at 50% load).
As the specification table above shows, the U-75HA features four +12v rails rated at 18a each with a maximum load of 648w (54a). This realistically brings the maximum output of each rail down to 13.5a if each rail were to be equally loaded at the same time (as we will be doing during the testing). Interestingly the ASUS website calls these rails "real four 12V rails" which by our definition is highly unlikely as it would require four separate 12v transformers. More realistically the U-75HA has one 12v transformer that is 'virtually' split into four with over current protection kicking in at 18a on each of the' virtual' rails.
The other main rails: +3.3v and +5v are both rated at 30a each with a maximum load across both rails of 160w. Although the technique for calculating the amperage output of each rail is not quite as simple as the +12v rails as there are two different voltages to contend with (+3.3v & +5v) , heavily loading the PSU in either direction still leaves a reasonable amount of power for the other rail.
Now let's move on to the unboxing of the U-75HA and its external appearance.
Great to see the new bit of kit put to good use. Power supplies are something people tend to overlook when buying hardcore hardware, even though it's the heart of the machine, so to get some serious numbers is fantastic!
VBQuote
like Diablo said, it should be 700W so it wount failt at 100% since it couldn't take the atx standards.
Also when i read DELTA i said: "god there's a delta as psu fan
after i readed it all, i can say that if it's not alot cheaper (half at minimum) of the price of a corsair 620, its not a good idea buying it, at least for me.
ops forgot (edit time)
great review Jim pretty objective, you told us about every thing in every spot of this psu, sadly it isnt an awesome one but thats asus fault lol.Quote
Not that I am complaining of course; I really look forward to seeing some of the data/results!Quote
All in all a bit of a dissapointing product. I'm not sure it deserves the 7.5 performance really.
Still nicely presented and great review, nice to see temperature readings and finally have a look at the PSU tester.Quote
