Coolermaster Real Power Pro M1000 1000w Modular PSU
Test Results
Load & Efficiency Tests
To provide our readers with the most accurate results, Overclock3D uses a custom built PSU load tester on all reviews. This not only gives much more reliable results than the testing methods employed by other sites, but also allows for all current and future review results to be compared side-by-side.
Efficiency tests are performed by measuring the wattage consumed by the power supply at the mains (Mains Draw) against the power consumed by the OC3D power supply stress tester (PSU Load). These results may not be 100% accurate, but have proven to be extremely close to results obtained from professional equipment.
 0%50%100%
+3.3v Rail0w66w99w
+5.0v Rail0w50w100w
+12v Rail(s)0w360w720w
Total0w443w919w
Coolermaster Real Power Pro M1000 Load Tests
The M1000 manages extremely good voltage regulation even at a huge 919w load. All rails remained within their ideal values throughout the testing, and I'm certainly confident of Coolermasters claim that this unit can produce a peak output of 1200w.
Coolermaster Real Power Pro M1000 Efficiency Tests
Coolermaster claim an efficiency level of 85%+ on the M1000, however during our testing the maximum efficiency level results we could obtain was 83.11% at 443w load. This certainly isn't a bad result as many PSU's are still hovering around the 80% efficiency mark, but it would have been nice to see our results mirror Coolermasters quoted levels.
Temperature Testing
In our continuing efforts to make power supply reviews more thorough, rather than simply checking voltage stability, Overclock3D will now be recording the temerature of each PSU as it undergoes testing. Temperature recordings will be taken from the underside of the PSU's outer casing at 0%, 50% and 100% load levels using a laser infrared thermometer in an attempt to gauge how much heat is likely to radiate into the end-users case.
Coolermaster Real Power Pro M1000 Temp Testing
With a 10°c difference in casing temperature from idle to full load, the 135mm fan inside the M1000 certainly doesn't seem to have any problems keeping everything cool. This is quite a relief, as one of the potential problems I highlighted earlier in the review was the cramped interior of the unit.
Noise Level Measurements
Possibly the hardest part of any PSU review is summarising the level of noise given out by the unit. The threshold for what is considered 'noisy' varies from person to person and therefore what I may consider a quiet unit, another person may consider extremely loud. For this reason, all reviews from this point forward will be using a dBA meter to measure the level of noise output by the PSU.
All noise measurements are taken in a quiet room with the dBA meter located 30cm away from the exhaust fan on the unit at 0%, 50% and 100% load levels. The results shown below have had the ambient noise levels deducted from the results to give a better representation of how likely you are to hear the PSU in a normal environment.
Coolermaster Real Powe Pro M1000 Noise
At both 0% and 50% loads there was very little audiable change in PSU noise levels with our dBA meter only registering a 4dBA increase. Moving up to 100% load caused the 135mm fan in the M1000 to speed up significantly, resulting in a 9dBA rise in noise levels.
Being the first PSU on OC3D we've tested using this method, it's hard to comment on the performance compared to some of the previous 1kw units we've reviewed. However, I will say that from a personal standpoint I found the M1000 to be very quiet at low to medium loads, and perfectly acceptable for my tolerances at full load.
«Prev 1 2 3 4 5 Next»
16-10-2007, 12:16:34
Bungral
Quality review
Liking the inclusing of temp recording.
Seems a top piece of kit.Quote
16-10-2007, 12:39:10
WC Annihilus
Personally I would consider no back power switch as a "bad" rather than just "mediocre" cause it's really inconvenient, but meh. Solid review Quote
22-10-2007, 02:54:10
Nagaru
A great review and a solid looking PSU. Just one question why was "Fairly cool operation for a 1000w unit." Listed under mediocre?Quote
22-10-2007, 15:45:12
SuB
hmm i'll be in the market for a new psu soon i think... this has certainly caught my eye!
will have to go through the other PSU reviews though but i do like the look of this
good reviewQuote
13-12-2007, 16:02:16
barginbin
Im looking for a 1000w PSU so this maybe one to consider although the TT(im goign to get flammed!!) Toughpower looks good and also comes with a 5 year warrenty.Quote
