Corsair AX 1200w ATX PSU Review
Simulated Load Results (Table)
Simulated Load Results (Data)
If you've seen the simplified graphs over on the previous page you will undoubtedly already have a good idea of how the Corsair AX1200 performs. However, certain results from the test can be too dificult to incorporate into the existing graphs, and for this reason all of the result data is also provided in the table format below.
All testing is conducting using OC3D's trusty SunMoon SM-268+ DC load tester. This equipment is capable of placing a user specified load on all of the PSU's rails (+3.3v, +5v, +12v, -12v, +5vSB) up to a maximum load of 1680w.  As the maximum load for this device on the +12v rail is restricted to 75A we will also be calling on additional help from our Analogic Series 2000 DC load tester, so that anything up to an additional 166A can be added if necessary. All testing is conducted at 50°C (±5%) with the results being recorded using a Fluke Multimeter and Thermostat.
Corsair AX1200 1200w @ 50°C
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test1
(25%)
5.50A 5.50A 21.25A 0.87A  0.20A 356w /
327w
91.85% 50.0°C /
50.9°C
0.9°C
3.36v 5.03v 12.18v 5.02v  -12.28v
Test2
(50%)
11.00A 11.00A 42.50A 1.75A  0.40A
661w /
619w
93.64%  50.0°C /
54.0°C
4.0°C
3.32v 4.98v 12.12v 4.95v  -12.31v
Test3
(75%)
16.50A 16.50A 63.75A 2.62A  0.60A 980w /
915w
 93.36% 50.2C /
55.2°C
5.0°C
3.26v 4.94v 12.06v 4.89v -12.32v
Test4
(100%)
22.00A 22.00A 85.00A 3.50A 0.80A 1347w /
1206w
89.53%  50.2°C /
62.0°C
10.2°C
3.23v 4.90v 12.04v 4.84v -12.31v
TestX1
(x-load)
22.00A 22.00A 1.00A 0.00A 0.00A 235w /
193w
82.12% 50.1°C /
49.9°C
-0.2°C
3.27v 4.95v 12.20v 5.05v -12.30v
TestX2
(x-load)
 1.00A  1.00A  62.00A  0.00A  0.00A 1300w /
1191w
91.61% 50.0°C /
57.9°C
7.9°C
3.35v 5.02v 12.08v 5.03v -12.32v
TMax1
(Max)
 22.00A 22.00A 114.00A 3.50A 0.80A 1760w /
1522w
86.47% 51.0°C /
64.2°C
 13.2°C
3.22v 4.90v 12.04v 4.84v -12.32v
OK. Before we even talk about anything else, I think you should take a look at the DC Watts being pulled in test TMax1. Yes, you did read that right. That's a whopping 1522W that the AX1200 can output continuously. At one point I even got it up to 1600W, but unfortunately it turned off after a few minutes. This is also testament to the OCP functioning properly on the unit. No matter how much I overloaded it by, or how many times I switched it straight back on after it had cut out, the AX1200 WOULD NOT GO BANG!
The rest of the results speak for themselves to be honest. Good voltages (especially on +12v) throught all of the tests, no weird voltage see-saw results during the cross-load tests, no exhaust temperatures suitable for stripping paint from your walls and efficiency levels that would give Captain Planet a reason to retire.
Corsair AX1200 Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test1
(25%)
Corsair AX 1200w  ATX PSU Corsair AX 1200w  ATX PSU Corsair AX 1200w  ATX PSU
Test2
(50%)
Test3
(75%)
Test4
(100%)
TestX1
(x-load)
TestX2
(x-load)
TMax1
(MAX)
Ripple.....what bloody ripple. I almost felt like that idiot who stands up on the stage saying "is this thing on" into the microphone. Tests 1-4 are flat, flat, flat and flat with no more than 24mV being recorded at any stage. The cross-load tests are also equally as uninteresting, and it's only when we get to the max-load test and seriously give the AX1200 a kicking that it puts out a still quite measly 42mV on the +12v rail. Awesome job Corsair!
«Prev 1 2 3 4 5 6 Next»
25-06-2010, 11:04:15
killablade
Wow. That is simply amazing!
oh btw you forgot a C in the title Quote
25-06-2010, 12:57:57
alienware
Beast.Quote
25-06-2010, 17:21:54
VonBlade
I was lucky enough to see the results prior to it going live.
It is truly epic. With a price-tag to match. Ouch.
But clearly if you want the best...Quote
25-06-2010, 17:25:26
tinytomlogan
I dont think its too bad, the aging HX1000w is still selling for £190, so for all that power and gold efficiency then I dont think its too bad. Just found it at scan for £246 now too.....Quote
25-06-2010, 18:04:43
TH3 H4NGMAN
Am I the only one who finds 6 pcie connectors lacking? Corsair's own 850W unit has 6, which has 30% less power. Antec's 1200W has 8 and the OC edition has 12!Quote
