Corsair HX620 620w Modular PSU
The following information has been taken directly from Corsair's website:
"From the manufacturer of the "World's Most Awarded Memory" comes the Corsair HX Series Power Supply. With that same legendary focus on the performance and reliability, Corsair has engineered the HX Series to support even the most demanding of systems. The Corsair HX Series incorporates the most advanced technology to deliver reliable, continuous, and efficient power to all critical system components. The HX Series is the ideal power supply for high performance and gaming PCs, Audio/Video workstations, and file servers."
• Supports the latest ATX12V v2.2 and EPS12V 2.91 standards and is backwards compatible with ATX12V 2.01 systems.
• Guaranteed compatibility with dual-GPU configurations.
• Double forward switching circuitry design offers high efficiency, up to 80% under wide load range.
• Active Power Factor Correction with PF value=0.99 provides clean and reliable power to your system.
• Universal AC input 90~264V automatically scans and detects the correct voltage. No more hassle of flipping that tiny red switch!
• Ultra quiet 120mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
• Guaranteed to deliver rated specifications at 50ºC.
• Triple 12V Rails provide independent reliable power to the CPU, video card and other components with a combined rating of 50A (40A on 520W) maximum! Advanced circuitry design that automatically enables power sharing between the triple +12V rails in an event of overload on any single +12V rail.
• Powerful +5Vsb rail with 3A rating.
• Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components.
• 105ºC rated industrial grade capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85ºC rated capacitors.
• Enhanced modular flexible cables enable easier cable routing and increased airflow in the system.
• Gold Plated connectors provide oxide free ultra low-resistance contact between the power supply and your critical components.
• 8 Serial ATA connectors (4 on 520W).
• Dimension: 5.9"(W) x 3.4"(H) X 5.9"(L) 150mm(W) x 86mm(H) x 150mm(L)
• MTBF: 100,000 Hours.
• Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick.
Noise Level
The HX620 appears to have some very impressive specifications including ~85% efficiency, noise levels of around 35dbA under 100% load and triple +12v rails rated at 18 amps each. Corsair also claims that each of the +12v rails are able to share power, thus meaning that if any one of the 3 rails becomes overloaded, one of the other rails will be able to assist.
«Prev 1 2 3 4 5 6 7 Next»
27-11-2006, 10:05:17
Had a quick flick though. Another good job Mr XMS.
Seems very pricy to me though.Quote
27-11-2006, 10:19:56
Mr. Popo
oO0o... very nice!
27-11-2006, 11:10:28
Originally Posted by name='Mr. Popo'
Read the review, its in there.Quote
27-11-2006, 11:24:35
Mr. Popo
I've read it twice, nothing...
Can I see a quote?Quote
27-11-2006, 11:28:06
Can I see a quote?
"For a ~600w unit the sum of £96 (over at may seem a little higher than most other competing products, however as the saying goes - "You get what you pay for", and this is certainly true for the HX620."
