Cougar 1000CM 1000w PSU Revisited
Simulated Load Testing
To provide accurate and consistent results in all of our PSU testing, Overclock3D uses professional grade DC electronic load equipment capable of placing a sustained load of 3690w across a total of six rails (including +5vsb and -12v) on the PSU! This is achieved by using a combination of SunMoon and Analogic electronic load equipment which allow us to adjust amperage loads in increments as small as 0.01A while also measuring voltage and wattage readings on-screen.   During today's tests, we will be placing the Cougar 1000CM under 25%, 50%, 75% and 100% load levels inside a hot box regulated to a temperature of around 50°C. Additional 'Cross Load' and a 'Max Load' tests will also be performed under these conditions to simulate how the PSU reacts to heavily uneven loads as well as running above its specified output.
Cougar 1000CM Results @ 50°C
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test 1
(Low)
5.25A 5.25A 16.75A  1.00A  0.20A  294w /
256w
 87.07% 52.4°C /
47.0°C
-5.4°C
3.35v 5.09v 12.25v 5.06v  -11.88v
Test 2
(Med)
10.50A 10.50A 33.50A 2.00A  0.40A  567w /
510w
 89.94%  50.1°C /
50.5°C
0.4°C
3.30v 5.02v 12.18v 4.98v  -11.89v
Test 3
(High)
15.75A 15.75A 50.25A 3.00A  0.60A  851w /
758w
 89.07% 50.1°C /
54.2°C
4.1°C
3.23v 4.95v 12.10v 4.90v -11.90v
Test 4
(Full)
21.00A 21.00A 67.00A 4.00A 0.80A 1147w /
1003w
87.44%  49.5°C /
59.5°C
10.0°C
3.19v 4.87v 12.02v 4.83v -11.92v
Test 5
(x-load)
21.00A 21.00A 1.00A 0.00A 0.00A  230w /
185w
80.43% 49.6°C /
50.8°C
1.2 °C
3.30v 4.95v 12.25v 5.08v -11.95v
Test 6
(x-load)
 1.00A  1.00A 80.00A  0.00A  0.00A 1103w /
966w
87.57%  50.0°C /
56.0°C
 6.0°C
3.32v 5.06v 12.02v 5.03v -11.99v
Test 7
(MAX)
 21.00A  21.00A 70.00A 4.00A 0.80A 1247w /
1031w
82.67%  52.3°C /
66.4°C
 14.1°C
3.21v 4.88v 12.00v 4.79v -12.00v
Cougar 1000CM Performance Overview
 +3.3v Diff.
T1-T4
 +5.0v Diff.
T1-T4
 +12v Diff.
T1-T4
Avg Effic.
T1-T4
Noise Rating
-4.77%   -4.32% -1.87%  88.38% Low
The performance overview chart is the first port of call, and here we can see that the Cougar 1000CM managed to hold extremely respectable voltage stability on its +12v rail between test 1 and test 4 with a drop in output of only 1.87%. Granted this isn't a record breaking result, but it's still around 1.4% better than the HEC built 1000CM and even outperforms a lot of the PSU's in top 10 list. Unfortunately the results from the +3.3v and +5v rails spoil the mood a little with both being quite "high". I say high with inverted comma's as the result its self isn't too shabby at all, it just foils any chance of the Cougar finding its way anywhere near the top of our leader board.
During the cross-load tests 5 & 6 the Cougar copes surprisingly well with no out-of -check voltages at all. Only the efficiency takes a nose-dive during test 5, dropping to just over 80%. This is a fairly surprising result considering the average results from the other tests so far, but very few PSU's pass these tests so the Cougar deserves a few points here at least.   Finally in the MAX Load test, it is quite obvious to see that the Cougar 1000CM is already stretched to its limits as far as power output is concerned. Although the unit was briefly capable of up to ~1400w before OCP/OPP kicked in and shut it down, the maximum sustainable load was just 1031w. Obviously at this load the voltages were quite similar to those at 1000w in Test 4 with the only difference being approx 4% lower efficiency at 82.67%.
And now for the moment of truth. Will all those solid state caps help to tame the beastly ripple results seen on the HEC badged 1000CM, or will Cougar be added to the swearword list on the Overclock3D forums? I can almost hear the knorring of fingernails at Cougar HQ....
Cougar 1000CM Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test 1
(Low)
Test 2
(Med)
Test 3
(High)
Test 4
(Full)
Test 5
(x-load)
Test 6
(x-load)
Test 7 (MAX)
WOW what an improvement. It's almost like somebody took the original HEC 1000CM ripple results to the hairdressers and asked for a number one all over! Gone are the massive mohawk-like spikes of ripple that hit over 300mV and instead we're left with what looks at first glance like some pretty acceptable results.
But don't go cracking open the bottle of champagne just yet...
While the ripple results from tests 1-3 are more than acceptable with results hovering around the 30mV mark for all of the rails, the +3.3v rail looses its cool in test 4 by exceeding the ATX Specified maximum ripple output of 50mV. Sure it's not by any massive amount, but considering the insides of the 1000CM has more solid state capacitors than an ASUS motherboard, I was at least hoping that it could keep up with the other units that we've tested recently.
This aside though the rest of the results are quite acceptable with the +12v rail especially managing to stick below 60mV no matter what was thrown at it. If Cougar could add just a little bit more filtering to the DC-DC boards for the +3.3v and +5v rails then I'd have no quibbles at all.
Now let's move on to the all important conclusion...
«Prev 1 2 3 4 5 Next»
22-01-2010, 12:08:19
killablade
One thing that I immediately thought of is: Damm that would look good in MNR 1.2 ^^Quote
22-01-2010, 12:19:56
tinytomlogan
HAHAHAHA the original was bound for MNR but the specs were not good enough tbh.Quote
22-01-2010, 13:06:40
JN
Aye. The appearance is so unique it almost makes me want to start an orange PC project
(Tom...i jest...no really...dont hit me)Quote
22-01-2010, 13:09:47
tinytomlogan
As long as I can shot blast red wrath first.......... meh Quote
22-01-2010, 15:03:35
f0x.
Great review, shame about that niggling ripple. Should be used in a fair few builds to come!Quote
