Silver Power SP-850M 850W Modular PSU Review
Test Results (Data)
Simulated Load Results (Tables)
If you've seen the simplified graphs over on the previous page you will undoubtedly already have a good idea of how the Silver Power performs. However, certain results from the test can be too difficult to incorporate into the existing graphs, and for this reason all of the result data is also provided in the table format below.
All testing is conducting using OC3D's trusty SunMoon SM-268+ DC load tester. This equipment is capable of placing a user specified load on all of the PSU's rails (+3.3v, +5v, +12v, -12v, +5vSB) up to a maximum load of 1680w. To make the testing even more grueling, the PSU is also locked inside a 50°C (±5%) 'hot-box' with all results being recorded using a Fluke digital Multimeter and Thermostat.
Silver Power SP-850M 850W @ 50c
  +3.3v +5.0v +12v +5vSB -12v AC Watts /
 DC Watts
 Efficiency Intake /
 Exhaust
Δ Temp
Test1
(25%)
4.50A4.50A14.25A0.75A 0.12A245w /
214w
87.34%49.6°C /
49.9°C
0.3°C
3.35v5.01v12.06v5.07v -11.86v
Test2
(50%)
9.00A9.00A28.50A1.50A 0.25A
475w /
428w
90.10% 50.2°C /
54.3°C
4.1°C
3.32v4.98v12.02v5.03v -11.87v
Test3
(75%)
12.50A12.50A42.75A2.25A 0.37A700w /
630w
 90.00%51.5C /
57.3°C
5.8°C
3.28v4.94v11.98v4.99v-11.88v
Test4
(100%)
18.00A18.00A57.00A3.00A0.50A977w /
847w
86.69% 50.4°C /
60.0°C
8.5°C
3.25v4.90v11.93v4.95v-11.88v
TestX1
(x-load)
18.00A18.00A1.00A0.75A0.12A203w /
165w
81.28%50.7°C /
50.7°C
0.0°C
3.31v4.95v12.06v5.05v-11.87v
TestX2
(x-load)
 1.00A 1.00A 57.00A 3.00A 0.50A790w /
710w
89.87%51.6°C /
58.2°C
6.6°C
3.32v4.98v11.96v4.99v-11.84v
TMax1
(Max)
 22.00A22.00A66.00A3.00A0.50A1137w /
983w
86.45%50.1°C /
58.8°C
 8.7°C
3.22v4.86v11.90v4.93v-11.91v
To reiterate what has already been said over on the previous page, the SP-850M has above average levels of voltage stability across the board with a fluctuation of 0.10v from idle to full load on the +3.3v rail, 0.11v on the +5v rail and 0.13v on the +12v rail. Efficiency is well above what is expected of a 'Bronze' unit with a peak of ~90% during tests 2 and 3 where quite frankly most buyers of this PSU will probably be running it at the majority of the time.
There is also room to run the SP-850M a little higher than indicated too, with our TMax1 result showing that the PSU was more than happy to pump out 983w continuously with only a small dent in the efficiency and voltage stability results.
Silver Power SP-850M 850W Scope Results @ 50c
  +3.3v +5.0v +12v
Test1
(25%)
Silver Power SP-850M 850W Modular PSU ReviewSilver Power SP-850M 850W Modular PSU ReviewSilver Power SP-850M 850W Modular PSU Review
Test2
(50%)
Test3
(75%)
Test4
(100%)
TestX1
(x-load)
TestX2
(x-load)
TMax1
(MAX)
WOW! Can we get a defibrillator in here, because it would appear that the SP-850M just flat-lined and is in need of some resuscitation! In case you are wondering, this is an extremely good result as the ripple results above refer to the small fluctuations in voltage that occur in all PSU's on a millisecond scale. Large quantities of ripple on a PSU can damage or kill components in your PC over time and therefore for a PSU to output such insignificant levels of ripple across most of the testing is simply amazing. So amazing in fact that I had to triple test the unit and even plug in a different PSU just to make sure that my scope hadn't gone wonky.
Well done Silver Power! Now let's move on to the conclusion...
«Prev 1 2 3 4 Next»
19-06-2012, 10:51:38
Josh Weston
Not everyday that you see a company underrate it's product for so much. Still, £100 for a bronze rated 850watt would seem a little much to me. £100 for a gold rated 850 watt...that's a bargain and a half.Quote
19-06-2012, 10:53:11
tinytomlogan
Originally Posted by Josh Weston View Post
Not everyday that you see a company underrate it's product for so long. Still, £100 for a bronze rated 850watt would seem a little much to me. £100 for a gold rated 850 watt...that's a bargain and a half.
£100 for gold? Id be worried mate not happy.Quote
19-06-2012, 10:55:23
Josh Weston
Be worried that your Bronze rated PSU was over-performing when it came to efficiency? Quote
19-06-2012, 10:59:55
Rastalovich
I used to buy Silverpower alot when the majority of systems only needed 400-500w. Very underated company imo, and not one to blow their own trumpet. Decent pricing verging on budget.
... gorilla ... what were they thinking ??Quote
19-06-2012, 11:13:44
PetrolHead247
Wow, what an absolute bargain!Quote
