Super Flower Leadex Platinum 1200W Review
12V Reading
12V Reading
The stability of the 12V rail is vital in ensuring the stability of your system and the lifespan of your components. You have to push the Leadex Platinum very hard indeed to get the 12V down to around the 12V mark, although the extra 10th of a volt in lower applications wont cause issues and there is very little difference between the PSU's in this graph its mainly here for that time we do find a problem and it will be very easy to point it out.
«Prev 1 2 3 4 5 6 Next»
17-10-2014, 09:15:28
Master&Puppet
Nice review Tom. I was excited when I saw this; white, LEDs, platinum and that price! Shame it didn't quite live up to the expectations it put upon itself but that price is still awesome.
M&PQuote
17-10-2014, 11:49:35
Modzy
This is the first PSU I've really liked the aesthetics look of since this old PSU which was launched back in 06.
Effeciancy aside, Tom do you think that the fan noise is down to the ugle press cut fan grill? Do you think if you where to cut out that grill and install a higher grill like this one that would fix the noise?
It seems like making doing this mod would be very simple and could have a positive impact on the noise level. If it isn't the grill causing that turbulent noise it may just be a bad low quality fan design that they have used.Quote
17-10-2014, 11:54:50
tinytomlogan
Originally Posted by Modzy View Post
This this is the first PSU I've really liked the aesthetics look of since this old PSU which was launched back in 06.
Its motor noise as well dude - I think its just a poor fan IMHOQuote
17-10-2014, 11:58:20
TPC
it is indeed a cheapo fan:
http://www.techpowerup.com/reviews/S...es/in_fan1.jpgQuote
17-10-2014, 11:59:14
Modzy
Hmm well that sucks I was hoping to replace my now ageing OCZ PSU with this nice white one. But I may hold off for a 2nd revision of this.
*Thanks for that image TPC. It really is a cheapo fan. Looks like it's even pure dc voltage controlled not even a 3pin thermal or pwm.
I would have been happy to pay even $50 more if it had a better fan design. I'm still running this old thing. It's power Isn't bad but the red lighting clashes badly with my case theme & It's horrid rubber flat cables are the worse design I've ever seen. Only reason I've got it is it was a prize I won at a LAN event.Quote
