Call of Duty Infinite Warfare PC Performance Review
Graphical Options and Settings
When it comes to graphical options, Call of Duty Infinite Warfare does a great job to provide PC gamers with plenty of choices and even going so far as to add an FPS overlay to the game, eliminating the need for external FPS measuring applications.
One other neat addition is dedicated render resolution options, which will allow PC players to select your displays native resolution or to play the game at higher or lower internal resolution depending on your PC's performance. If you want to achieve a higher framerate players can simply lower the game's internal resolution, or increase it if they wish to improve the game's visuals through supersampling.
In singleplayer, the game has a framerate cap of 125 and in multiplayer the game will have a framerate cap of 90, with the game having FOV options that are between 80 and 110 in both modes.
While testing the game we will be playing the game at the below graphical settings, allowing our readers to see exactly how the game performs at the lowest and highest graphical settings. We will also be testing the game with various resolutions, allowing you to easily see what GPU can play this game at standard resolutions like 1080p or at Ultra-high resolutions like 4K.
Call of Duty Infinite Warfare PC Performance Review  Call of Duty Infinite Warfare PC Performance Review
(Low (Left), Medium (Right))
  (High (Left), Ultra (Right))
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
06-11-2016, 15:46:22
NeverBackDown
480 beats a 980ti at 1440p? Well that was a shocking result to come by. Has COD always favored AMD like this?
Regarding vram consumption, many many games run like that. Use as much as possible even if it's not needed. It's faster to pull from memory than it is to reprocess something, think this is called hardware/shader/etc streaming or something like that.Quote
06-11-2016, 17:36:12
AngryGoldfish
I'm wondering this as well. The last COD favoured AMD as well, but I don't know whether that's true of issues going further back.
On a different note, I like that your review isn't just a slugfest of hatred. The game clearly deserves praise for its excellent performance and options, but the terrible decision (if it was indeed a 2-way decision) to split the community really puts a downer on everything. Also, I wish the graphics and level design had a little more... guts. It just looks so safe and dull at this stage.Quote
06-11-2016, 23:47:45
Kushiro
Funny how the 1070 is all the way up top like it should be, whereas the 980ti cant even beat a mid ranged gpu...Quote
07-11-2016, 00:32:43
Dicehunter
It's a telltale sign of how unoptimized either the game or the drivers are as an RX-480 should not be beating a 980 Ti at all at anything.Quote
08-11-2016, 02:16:33
Thunder-74
There is a problem with this test.... with a 980ti (@1480/7600) I have many more frames at 3440x1440 and all settings on max. about 80 fpsQuote
