Call of Duty Infinite Warfare PC Performance Review
1080p Performance
1080p Performance
When it comes to 1080p game performance anything like the RX 480 and GTX 1060 will easily achieve 60+ FPS average framerates at max settings, with steady framerates being fairly achievable at lower setting on our lower end R9 380 and GTX 960.
We can see that at 1080p Max settings that the GTX 960 and R9 380 struggle to achieve steady framerates, though once we lower the levels of SMAA and some shadow details a steady 60FPS is achievable.
Moving to the RX 480 and above we can see that it gets harder to differentiate the higher end GPUs, as the game's maximum framerate is limited to 125FPS in singleplayer making the minimum framerate data much more important for the highest end GPUs.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
06-11-2016, 15:46:22
NeverBackDown
480 beats a 980ti at 1440p? Well that was a shocking result to come by. Has COD always favored AMD like this?
Regarding vram consumption, many many games run like that. Use as much as possible even if it's not needed. It's faster to pull from memory than it is to reprocess something, think this is called hardware/shader/etc streaming or something like that.Quote
06-11-2016, 17:36:12
AngryGoldfish
I'm wondering this as well. The last COD favoured AMD as well, but I don't know whether that's true of issues going further back.
On a different note, I like that your review isn't just a slugfest of hatred. The game clearly deserves praise for its excellent performance and options, but the terrible decision (if it was indeed a 2-way decision) to split the community really puts a downer on everything. Also, I wish the graphics and level design had a little more... guts. It just looks so safe and dull at this stage.Quote
06-11-2016, 23:47:45
Kushiro
Funny how the 1070 is all the way up top like it should be, whereas the 980ti cant even beat a mid ranged gpu...Quote
07-11-2016, 00:32:43
Dicehunter
It's a telltale sign of how unoptimized either the game or the drivers are as an RX-480 should not be beating a 980 Ti at all at anything.Quote
08-11-2016, 02:16:33
Thunder-74
There is a problem with this test.... with a 980ti (@1480/7600) I have many more frames at 3440x1440 and all settings on max. about 80 fpsQuote
