Call of Duty Infinite Warfare PC Performance Review
4K Performance
4K Performance
Moving up to 4K we start to see even the mighty GTX 1080 struggle to achieve an average framerate of 60FPS, achieving an average framerate of 58.47 FPS. Again we can also see the AMD R9 Fury X easily beating the GTX 1070 when it comes to average framerate, but both have similar minimum FPS numbers.
Unless you have a GTX Titan X Pascal a steady 60FPS will not be possible at 4K in the campaign at max settings, though every GPU below will be able to achieve a steady 60FPS at lower game settings.
At 4K players will easily be able to turn down the SMAA to lower settings with little visual downgrade or increase in aliasing, though most of these GPUs will need to some lower shadow quality settings and other settings changes to achieve a solid 60FPS framerate.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
06-11-2016, 15:46:22
NeverBackDown
480 beats a 980ti at 1440p? Well that was a shocking result to come by. Has COD always favored AMD like this?
Regarding vram consumption, many many games run like that. Use as much as possible even if it's not needed. It's faster to pull from memory than it is to reprocess something, think this is called hardware/shader/etc streaming or something like that.Quote
06-11-2016, 17:36:12
AngryGoldfish
I'm wondering this as well. The last COD favoured AMD as well, but I don't know whether that's true of issues going further back.
On a different note, I like that your review isn't just a slugfest of hatred. The game clearly deserves praise for its excellent performance and options, but the terrible decision (if it was indeed a 2-way decision) to split the community really puts a downer on everything. Also, I wish the graphics and level design had a little more... guts. It just looks so safe and dull at this stage.Quote
06-11-2016, 23:47:45
Kushiro
Funny how the 1070 is all the way up top like it should be, whereas the 980ti cant even beat a mid ranged gpu...Quote
07-11-2016, 00:32:43
Dicehunter
It's a telltale sign of how unoptimized either the game or the drivers are as an RX-480 should not be beating a 980 Ti at all at anything.Quote
08-11-2016, 02:16:33
Thunder-74
There is a problem with this test.... with a 980ti (@1480/7600) I have many more frames at 3440x1440 and all settings on max. about 80 fpsQuote
