Far Cry 5 PC Performance Review
1080p Benchmarks
1080p Benchmarks
At 1080p Far Cry 5 presents very little to worry about if you are using GPUs like our RX 580 and GTX 1060 Strix models, easily giving us 60+ FPS at Ultra settings.
It is only when moving down to older GPUs like the R9 380 and GTX 960 present a challenge, though they both still offer a solid 30+ FPS, which means that players could lock the game's framerate to 30 and have a perfectly reasonable console-like experience at Ultra settings on these older GPUs. If you want to aim for 60FPS players will need to lower their graphical settings and display resolution or resolution scale, which we will explore later.
Moving past the GTX 1070 we can see that the RX Vega 56 and GTX 1080 offer similar performance levels overall, with the RX Vega offering steeper performance dips, which are likely due to a CPU related restriction.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
29-03-2018, 14:47:03
Greenback
Don't know if my poor eye sight is a blessing or a curse but once I get to high I can't tell the difference in high and ultraQuote
29-03-2018, 15:15:25
WYP
It really is difficult to tell, grass draw distance is one of the few things that I can see as well as some changes to in-game reflections. Not a huge deal of difference.Quote
29-03-2018, 20:11:08
Wraith
Honestly unless you really look for differences it's hard to spot them, as WYP has said and the extended shadows there is very little difference when actually playing the game.Quote
29-03-2018, 21:30:52
NeverBackDown
Pretty good performance I'd say.Quote
30-03-2018, 03:49:50
AlienALX
or RX Vega 56's in SLI
I'd love to see you try might wanna fix that.
Another fantastic performance article though Mark, thank you. I think the Titan should do fine at 4k Quote
