Far Cry 6 PC Performance Review and Optimisation Guide
4K Performance Tested - Ray Tracing On and Off
Published: 6th October 2021 | Source: OC3D Internal Testing | Price: |
4K - Still CPU/memory limited?
Far Cry 6 is well optimised on the GPU side, so much so that 4K Ultra settings isn't a challenge to today's high-end graphics cards. Beyond that, lower-end GPU models can utilise AMD's FSR feature to enable higher performance levels at 4K.
Thankfully, Far Cry 6 isn't very CPU-limited at 4K. That said, enabling FidelityFX Super Resolution will quickly show high-end GPU users that Far Cry 6's performance is CPU/memory constrained when high framerates are targeted. 4K 120 FPS is a challenge with Far Cry 6, even for those with sufficiently high-end GPUs.
When Ray Tracing is enabled, 60+ FPS framerates can be a challenge in Far Cry 6, which is what makes add-ons like AMD's FidelityFX Super Resolution incredibly valuable to PC gamers.
At 4K Ultra with RT enabled, GPUs with 8GB or less memory did suffer from performance issues. This is especially true for AMD's RX 6600 XT. Nvidia's 6GB RTX 2060 crashed frequently, making the test pointless. While Far Cry 6's VRAM indicator said that 6GB of VRAM is enough, our results clearly tell a different story.
Dont think I lasted 20mins before uninstalling it.Quote
