Gears of War 4 PC Performance Review
Gears of War 4 is a game that truly showcases what modern PC hardware is capable of, using the Unreal Engine 4 and the DirectX 12 API to create one of the most graphically impressive games that we have ever seen. With this comes some hefty PC requirements for steady framerates at Ultra settings, though it is worth noting that plenty of modern games offer much less graphical fidelity with much lower framerates when maxed out, making Gears of War 4 efficient and not just demanding.
In our testing Gears of War 4 proved to be a very demanding title, requiring a GTX 1070 or above for solid 1440p gameplay that remains mostly above 60FPS, making us see exactly why this game is only bundled with Nvidia's highest end GPUs. Thankfully, this game has lower graphical options to scale to lower end hardware, but only those with top of the range systems will be able to max this game out at 60+FPS and high in-game resolutions.
It is clear that this game has been designed to be used With the Xbox One Project Scorpio for 4K 30FPS console gameplay in the future, with the game sporting 4K ready textures and a huge attention to detail in its environments. Today's modern PC hardware is already capable of Project Scorpio's performance levels, giving us some spectacular visuals and some super high-resolution textures long before console gamers can get access to it.
Gears of War: Ultimate Edition was easily one of the most disappointing PC games of recent years, but The Coalition has been able to turn things around, making Gears of War 4 one of the best PC releases of 2016 in terms of quality. The game's graphical options menu is better than everything else that we have seen this year, with each option coming with detailed explanations on how much it will affect CPU performance, GPU performance or VRAM usage. This allows PC gamers to easily adjust the game to meet their framerate requirements on their current hardware, without the need for a long tinkering session.
Graphically Gear of War 4 looks spectacular at Ultra settings, making this game one of the few which could actually justify a hardware upgrade. We need titles like Crysis or Gears of War 4 to push the development of PC graphics hardware forward, as right now some companies seem to be sitting on their hands. Cough, GTX 1080Ti, Cough.
PC gamers should aim top play this game at High settings at a minimum if they want a great visual experience, as this is where the visuals-to-performance trade-off is best. For those with high-end hardware Ultra settings is simply a feast for the eyes if you can run it at a stable framerate, making the visual upgrade more than worth it for enthusiast PC builders.
Right now DirectX 12 has been a bit of a disappointment for most on PC, though Gears of War 4 really showcases what is possible if a game is made with DirectX 12 support in mind from the beginning, offering fantastic PC performance and breathtaking visuals from day one.
Looking at Async Compute we can see that it does not have much of an impact on the performance of Nvidia's Pascal GPUs and is not even an option on older Maxwell hardware. On AMD GCN and newer GPUs Async Compute offers a noteworthy performance increase, giving AMD GPUs that little bit of extra grunt to play this demanding new release. In the future, The Coalition plans on implementing DirectX 12 Multi-GPU support in a future patch, but for now, Gears of War 4 will only support single GPU setups.
Gears of War 4 is an Unreal Engine 4 masterpiece and the first UWP game on the Windows 10 store that we would recommend to PC gamers If you want an action-packed cover based shooter with great visuals Gear of War 4 is the best game in town right now and is a great sign of what is to come if Microsoft gives the PC version of other Xbox Play Anywhere titles the game quality control.
You can join the discussion on Gears of War 4's PC version on the OC3D Forums
13-10-2016, 16:23:05
AngryGoldfish
For every turd there is a chocolate bar.Quote
13-10-2016, 18:14:42
gijoe50000
Would be nice of they optimized the textures/game for certain amounts of vram. Having 4210MB makes no sense since the level down for 1080p is 2770MB. Everyone with a 4GB gpu will be missing out here.
There seems to be a huge gap between ultra and high..
It would make more sense to have the vram optimized as, say: 6GB for Ultra, 4GB for very high 3GB for high 2GB medium.
Does that make sense?Quote
13-10-2016, 18:47:06
NeverBackDown
Strange the only card using Async from Nvidia to lose performance was actually the 1080Quote
14-10-2016, 04:26:27
AlienALX
Might actually pull the trigger on this once I'm done with Mafia III (not even started yet lol).Quote
14-10-2016, 09:11:55
SPS
In UE4 you set a pre-defined texture streaming pool, this can either be set exactly or it can be set to be a percentage of VRAM. The streaming system well then only stream in the correct mips per texture where it is able to do so. If the texture pool is set to 20% of VRAM at low settings using 1080 (which has a fair bit of VRAM), it's possible that the VRAM report actually shows more VRAM being used than necessary. Once the pool is full it will only stream out textures when the memory being used is required for use by a texture coming into view. This helps prevent wasted time streaming out textures for the sake of it.
https://docs.unrealengine.com/latest...res/Streaming/Quote
