Gears of War 4 PC Performance Review
Control Options
Gear of War 4 is designed primarily to be played on Xbox One and as such has a variety of controller specific options on the PC. These options include vibration options, inverted control options as well as controller sensitivity options, PC gamers will also be able to select one of several pre-defined control schemes. Â
Sadly controller users will not be able to rebind their controls fully, though the normal controls are very user friendly. Â
Â
Â
Gear of War 4 can be controlled using Mouse and keyboard on the PC, with fully rebindable controls which will allow PC gamers to easily adjust the controls to their liking. Throughout my time playing the PC version of the game I have found both Mouse/Keyboard and gamepad based controls to be equally usable, though Gears of War veterans will likely prefer to use a gamepad.Â
