Gears of War 4 PC Performance Review
4K Performance
4K Performance
At 4K none of the GPUs that we have tested is able to play the game at a solid 60Hz, though with the level of visuals available in Gears of War 4 this is to be expected.  At Ultra setting the game is very playable with a GTX 1080, but players should lower their settings or resolution scale in order to achieve a more stable framerate.
Right now Gears of War 4 does not have support for DirectX 12 Multi-GPU, which means that even those with dual GTX 1080s will be unable to play the game at a solid 60FPS at 4K Ultra settings. Those with an insane amount of disposable income could try a GTX Titan X Pascal, but even then the game will play at a solid 60FPS.
13-10-2016, 16:23:05
AngryGoldfish
For every turd there is a chocolate bar.Quote
13-10-2016, 18:14:42
gijoe50000
Would be nice of they optimized the textures/game for certain amounts of vram. Having 4210MB makes no sense since the level down for 1080p is 2770MB. Everyone with a 4GB gpu will be missing out here.
There seems to be a huge gap between ultra and high..
It would make more sense to have the vram optimized as, say: 6GB for Ultra, 4GB for very high 3GB for high 2GB medium.
Does that make sense?Quote
13-10-2016, 18:47:06
NeverBackDown
Strange the only card using Async from Nvidia to lose performance was actually the 1080Quote
14-10-2016, 04:26:27
AlienALX
Might actually pull the trigger on this once I'm done with Mafia III (not even started yet lol).Quote
14-10-2016, 09:11:55
SPS
In UE4 you set a pre-defined texture streaming pool, this can either be set exactly or it can be set to be a percentage of VRAM. The streaming system well then only stream in the correct mips per texture where it is able to do so. If the texture pool is set to 20% of VRAM at low settings using 1080 (which has a fair bit of VRAM), it's possible that the VRAM report actually shows more VRAM being used than necessary. Once the pool is full it will only stream out textures when the memory being used is required for use by a texture coming into view. This helps prevent wasted time streaming out textures for the sake of it.
https://docs.unrealengine.com/latest...res/Streaming/Quote
