Kingdom Come: Deliverance Performance Review
VRAM Use - Are 4GB GPUs enough for this ultra-demanding title?
Published: 17th February 2018 | Source: OC3D Internal Testing | Price: |
As discussed previously, 2GB of VRAM is enough for 1080p gameplay at low or Medium settings, with high settings performing optimally with 3GB of VRAM or more. Moving up to Ultra setting we can see that 3GB of VRM remains adequate, but 4GB or more is preferred at 1440p.
Playing this game at a 4K resolution will require more than 4GB of VRM, with 6GB or more being optimal, though even then you will have to contend with the game's insane GPU requirements, which will require a GTX 1080 Ti or more to achieve 30+ FPS framerates at High settings.
Might have to pick up this game to give my new system a real work out
I recommend Very High since Ultra High doesn't seem that well optimized.Quote
Also this game isn't that bad to run for me. 1440p and a 1080 I am running just fine. There are some places where performance tanks and things do need to be addressed but thankfully that's not that often(like big battles or crowded streets).
I will say however that the texture streaming in this game is god awful. Got a mod that edits the settings and you can change how much memory this game consumes(it has such a low cap for memory, WH was ultra conservative it seems for consoles) and the texture streaming was immediately reduced. The dynamic settings WH used is super aggressive even on maxed out LOD settings. Still happens but far less noticeable with the "mod"(more like cfg file).
One other thing is they need to improve load times. I'm on a ssd and it's kinda long(for an ssd anyway). Can't even imagine HDD users.Quote
