Sniper Elite 4 Performance Review
4K Performance
4K Performance
At 4K we can see that all GPUs tested fail to achieve average framerates of over 50, though the GTX 1080 can offer some very playable framerates when using High graphical settings.
For a steady 60FPS gamers will need to use a lower resolution scale to enhance their framerates or use lower graphical settings, though SLI and Crossfire is an option here for enhanced performance.
15-02-2017, 07:10:24
Great info dump. I'd be interested to see a set of results with the CPU massively downclocked with all setting levels in both DX11 and DX12 versus stock clocks.Quote
15-02-2017, 13:59:12
Pascal still being picky with Async I see. Better then worse half the time. I think going from dx11 to 12 without Async, those tiny performance gains probably come from only the CPU, even with Async again half the time it's like that too. Although it is rather interesting to see that you get the best improvements at lower resolution and you get less and less in return as you crank up the settings.Quote
15-02-2017, 15:46:38
Another good showing from the Fury X. The HBM is proudly displaying its wings with the higher resolutions. Vega and future HBM-equipped GPU's by Nvidia and AMD will be excellent for higher resolutions.Quote
