Sniper Elite 4 Performance Review
RX 480 VS GTX 1060 - Low, Medium, High and Ultra Settings
In our testing, we found that both our GTX 1060 and RX 480 performed best under irectX 12 with Asynchronous compute active, with both GPUs performing similarly at 1440p Ultra settings.
At lower settings, we can see AMD start to gain an advantage here, though neither GPU achieves a perfect 60+FPS at 1440p. This can be fixed with a slightly lower resolution scale in game or a drop to a resolution like 1080p.
15-02-2017, 07:10:24
SPS
Great info dump. I'd be interested to see a set of results with the CPU massively downclocked with all setting levels in both DX11 and DX12 versus stock clocks.Quote
15-02-2017, 13:59:12
NeverBackDown
Pascal still being picky with Async I see. Better then worse half the time. I think going from dx11 to 12 without Async, those tiny performance gains probably come from only the CPU, even with Async again half the time it's like that too. Although it is rather interesting to see that you get the best improvements at lower resolution and you get less and less in return as you crank up the settings.Quote
15-02-2017, 15:46:38
AngryGoldfish
Another good showing from the Fury X. The HBM is proudly displaying its wings with the higher resolutions. Vega and future HBM-equipped GPU's by Nvidia and AMD will be excellent for higher resolutions.Quote
