Corsair Flash Padlock 2 8GB Review
Testing
Testing
Confession time now. When Corsair first came to us with the press release for the Padlock 2 and asked if we'd have any interest in reviewing it, we had absolutely no idea how we was actually going to 'test' the device. Sure we could line up the usual list of OC3D benchmarking programs, run off a load of result graphs and hope that nobody noticed that we avoided testing the most important feature of all - it's security. But with Corsair pounding it into our heads that "this drive is not designed for speed" from the outset, a quick run of Sisoft Sandra would never wash.
Hiring a 'hacker' would also be out of the question too. Plenty of people pertain to be 'hackers', yet most only really know how to use hacking utilities that other people have created. Not being 'hackers' ourselves we'd also have no idea if they were up to the job and whether an outcome such as "this drive is totally impenetrable" would actually be true. Additionally, hiring a verified security expert for the job would also be beyond our budget and a bit overkill considering it's just a USB stick we're looking at here.
And then it suddenly dawned upon us.
If we were unable to gain access to the drive and had to reset it thus wiping its contents, the first thing we'd do in order to try and recover what was on there previously would be to grab a copy of the best disk recovery tool we could find and set it to work on the flash drive. Could it really be this simple to get back that sensitive data? Let's find out...
Easeus Data Recovery Pro
Step 1: Set up a PIN number on the Padlock 2 and place an extremely important document on there. Server Passwords.docx - wouldn't you like to get your hands on that one? (It's actually the wifes shopping list).
Corsair Flash Padlock 2 8GB Secret File
Step 2: Test that the data recovery software is working by deleting the file from the drive and attempting to recover it. As we can see, Easeus has located the deleted file and is giving us the option to restore it.
Corsair Flash Padlock 2 8GB Recover 1  Corsair Flash Padlock 2 8GB Recover 2
Step 3: Place the file back on the drive, remove the drive from the PC and forget the PIN number. Oh no, now we need to reset the drives PIN resulting in our important document being wiped from the drive. But is it? Let's run the recovery tool over the now unformatted drive to see what it can pick up.
Corsair Flash Padlock 2 8GB Recover 3  Corsair Flash  Padlock 2 8GB Nothing
Nothing. Zip. Nadda. The drive was completely wiped clean with absolutely no traces of the previous data recoverable at all. Although this is by no means a scientific test, it certainly shows that a casual PC user would not be able to recover any data from the drive if they found it in the street. I think we can also be quite confident that even a seasoned Neo would have a tough time too.
DiskBench
Yes, I know we said that we wasn't going to run any performance benchmarks. But did you honestly believe us? At the very least we need just a rough idea of how the Padlock 2 performs. To do this we're going to be transferring a 3GB ISO file to and from the flash disk using DiskBench by NodeSoft. DiskBench is not to be confused with synthetic benchmarks as the sole purpose of the software is to time the transfer of a specified file between source and target drives. Based on the size of the file and the time taken, it can also calculate the average transfer speed in MB/s. The results are below:
The ATP Toughdrive chosen to be the Padlock 2's adversary is about the worst USB stick that we could dig up in the office, and unfortunately it still manages to give the Corsair a thorough pasting in the read results. On the up-side the writing results are more closely matched, but if you're expecting the Padlock 2 drive to be one of those sticks that you can quickly transfer a few hundred MB's of data over to on your way out of the front door in the morning, you're going to be quite disappointed.
«Prev 1 2 3 4 Next»
31-03-2010, 13:42:11
alexhull24
Disappointing performance for the price, but that is to be expected I guess.
If you look at this review, they claim the stick is a lot less secure as the code (from 5 digits) can be guessed as many times as you like with a little dismantling, which I'm sure any serious thief would have no qualms in doing. Fortunately, the chances are your average joe who'll pick it up once dropped will have no idea how to do this. The images also show why the thing is so chunky - it's mostly the rubber casing for durability.Quote
09-04-2010, 13:38:43
mayhem
10 million possible combination's. Take into account to hack it using a brute force method it would not take that long.
How ever a nice little draw back for you . In the other review corsair use resin to cover the pins to stop ppl getting to the memory. well i can tell you now that is easy to get around. They use the same method on the wii to stop ppl modding there firmware on the wii. Its not hard to get off at all.
They haven't fixed any problems at all from the last model they have just adopted their methods to suit their needs. that thing is as secure as a asda £1.99 belt. It looks good. It seems to fit, but as soon as you start using it, it will fail.
Its 5 keys not 10 - so they are lying and filling the user with bull.
Its doesn't have as many possible combination's as they say
the encryption is questionable to say the lest as the whole drive is unlocked not file by file.
The reset can be worked around by disconnection of the battery.
i love the proverbial bull these manifaures use to sell there products. Just give these USB Keys to the government and let them lose them on the trains as normal and lets see how long it takes for some one to pick one up and then attack's it and then sell's all you info onto to company's.
All so another note if the code like it says has a master is there a second master key that corsair has ... (a back door) ..
So a hardware hack would be some thing along the lines of
1) Pins 1,2,3,4,5 Are switches
2) Pin 6 is confirm (switch to the enter key)
3) a sensor to denote weather the red flashes or the green flashes. (red carry on / Green correct stop) A simple detection if there is a signal or not isnt hard to code up.
4) and a last connection to the negative on the battery to disconnect every 5 attempts to reset the drive.
5) total of 10 wires to a com port and on PC and a simple rite up of VB code to execute the commands in brute for mode staring from 00000 to 5555555555.
This would be a very simple circuit.
this thing reminds me of them tumble locks ppl have on there bikes because its about as effective as one. infant it would take you longer to decode a bike lock than one of those lol.
conclusion in reality . the product is not a effective solution to modern day problems at all. Its a cheap ineffective product that oky for the normal user but would pose a security risk if used in environments were secure data is of high importance. Personally i think the score is way to high and the price point is to high as well. (or do i just think out of the box)
No offence meant at the reviewer btw.Quote
09-04-2010, 17:36:56
tinytomlogan
Mayhem did you actually read the review or just trying to look for a fault? Would have been quicker to read it than all that ^^Quote
