GSkill Falcon 128GB SATA II SSD
Real World testing
Published: 13th July 2009 | Source: GSkill | Price: £268.99 |
Dummy File Creation
When performing manual "file copy" benchmarks, the performance of the drive that the files are being copied from can directly and negatively affect the results of the drive they are being copied to. This is something that needs to be taken into consideration when benchmarking high performance hard disks such as the OCZ Vertex SSD as it's performance easily exceeds that of a standard hard disk. Therefore, to test the write performance of each storage device a freeware utility called Dummy File Creator was used to generate files directly to each of the hard disks. The first 16GB benchmark writes a collection of files ranging in size from 1GB to 100KB, whereas the 100GB benchmark writes a single file of exactly that size to the disk.
Unreal Tournament 3 Level Loading
With a fresh copy of Vista installed on each hard disk, the final test was to find out if the Windows loading times seen above would also be applicable to the map loading time of a popular PC game. Once again, the test procedure was quite simple: Install Unreal Tournament III, load the game, select a map to play (ONS-Torlan) and measure the time taken from pressing the "Begin" button to the time the map is fully loaded. This procedure was repeated a total of three times on each of the hard disks, with a reboot in between each test to clear system memory.
Vista Boot/Shutdown Time
Quite a simple and self explanatory test. We took each of the disks, installed a fresh copy of Windows Vista SP1 on to them and measured the time each took to boot into the Windows desktop and display a text file placed in the startup folder. To ensure that the tests were fair the results were averaged over initial reboots. Shutdown time was also recorded, although this generally happened so quick that accuracy was hard to obtain.
Results Analysis
The random 16GB file creation was neck and neck between the Falcon and the Vertex but switch to the longer lasting test of a 100GB file and it is clear which SSD is the better performer.The Falcon managed to generate the 100GB file over 2 minutes quicker than it's nearest rival which is no mean feat considering the Vertex can hardly be accused of being a slouch in this department.
UT III level loading showed the Falcon to have the upper hand here too although the result was much closer with very little to chose between them. Much the same is to be said of the Vista start up and shutdown times.
Let's head over to the conclusion where I will try to give my overall view of the GSkill Falcon 128GB SSD...
Hmmm. Well Jim doesn't keep it because W3bbo reviewed it
Great review as always, I just find it hard to get excited about SSD because they're so freaking expensive. I'm sure they are quicker, but I come from the tape then floppy days so HDs still feel fast to me. But no matter how fast they are, 128GB of SSD vs 4TB of Spinpoint is a no brainer.
Maybe if you have a spare one W3bbo you can lend it to me so I can become enthused
VBQuote
VBQuote
Originally Posted by name='Bungral'
Maaaaaaaaaate!
How did this go un replied to? |
I do wonder if any1 else agrees with me on this - I would appreciate if they replied in agreement or not.. BUT..
I saw this review posted.. and I have tbh, skipped it. And as I thought about skipping it, I thought others will skip it too, from a reply pov, and here's my rationale atlest:
I can sum up the review without a read, 1x SSD, blazing speeds, low relative capacities, nice package with little content, extremely high price (£2+ a gig). To be fair this is all I/we need to know. The values can fluctuate a bit, but aslong as that last, almost the most important figure remains at around £2+ and the relative capacities are low - the interest stops there.
This is no reflection on the reviewer, as always I know the review will be outstanding. The reviews are always at a high level on OC3D.
However, until the manufacturers take their mindset away from corporations wanting these for their drive bays in their lovely raid setups, not minding paying £10k for the privilege, ur average enthusiast isn't going to be interested without some exception.
U know they're intended for these markets as they're content to stick with the lower capacities that almost mirror SCSI drives in similar raid setups (which are faster according to HDTach presets).
Now we've seen 320g drives emerging, so 250g will very soon be the distant maximum. No doubt 640g drives will follow eventually - but I can guarantee u that they won't come out until they've milked the higher prices of the lower capacities.
Soon as we atleast see £1.5 a gig. The masses will take more interest.
It's very basic for an enthusiast. They can't buy 2x GTX285 gpus - why spend the same budget on a small harddrive.
2 - cents !Quote
I see your point rasta and I do agree about the cost per gig which is terrible however, SSD's represent the best upgrade most consumers can buy. The general feel of the OS is so much snappier, it loads up quicker, as do games. I bought 2x1tb samsung F1 drives a couple of months back and after testing this drive I am regretting that decision. Sure it's nice to have oodles of storage (of which I now have 2TB!) but nothing can match the speed of SSD for desktops imo.Quote
I have an excuse... I had 800 posts to catch up on and then I save the reviews for last.. This is my last one so I'm now officially caught up.
Aaaanyway back to this review.. What a product really.. It actually beats the competition by a clear margin (mostly) which makes a change these days.
Don't ya get to keep this one Jimbo?
