Patriot Inferno 60GB SSD Review
Up Close
Published: 10th January 2011 | Source: Patriot | Price: £115 |
Up Close
The Inferno comes in a very shiny box with a little window that allows you to see the Patriot comes in a lovely shade of red rather than the more common and sedate black.
Internally there are two separate plastic cases, one containing the drive and one containing a 2.5" to 3.5" adaptor to allow you to install the drive securely in any case of your choosing.
The adaptor is identical to the Corsair Nova one we've seen, but that's by no means a bad thing as if it isn't broken you don't need to fix it.
The drive makes a lovely difference to the plain black ones with a white sticker than seem prevalent. It's a lovely shade of red in high quality brushed aluminium and the chromatic sticker really helps give an air of class to proceedings.
Internally everything is as you'd expect with the SandForce controller centrally mounted and surrounded by the memory chips. One of the benefits of SandForce is that it doesn't require a cache chip and so the board has more room than other variants.
Along with the SandForce controller the capacity is provided by Intel MLC NAND chips which give good performance.
Very Well written review Bryan, I do have a couple of questions and it may be an oversight by me, what OS were you using? and was it 32bit or 64bit. I do not know how much this may impact on results and wonder whether that is also a test that should be done just to see if different OS do make a difference. |
Test Setup
ASUS Rampage III
Intel Core i7-920 @ 3.8GHz
Noctua NH-D14
6GB Corsair Dominator GT
EVGA GTX570
Windows 7 x64
Its time for a new SSD for me ...Quote
