Sabrent Rocket NVMe 2280 M.2 Review
Up Close
Up Close
Many M.2 drives come in the bare minimum of packaging, as you might expect given that it requires no drivers or particularly complicated installtion instructions and will quickly be binned. The Sabrent approach is to encase the Rocket M.2 in a tin to ensure it survives your local postal service unscathed. We appreciate the large finger holes that allow you to remove it without placing any undue stress upon the already thin PCB.
We have the 4TB model on test today, which has NAND chips on both sides of the drive. The compact nature of the E12S controller enables the 2TB and under models to be single sided, but at this capacity it's too much to ask so both sides it is.
Beneath both labels are thin copper heatspreaders doing their best to average out any heat generated across the entirety of the PCB. Those of you with motherboard M.2 heatspreaders will be glad to know there is no large heatsink to remove. Fit and forget.
The cache takes the form of the Nanya Technology NT5CC256M16ER-EK, which is a DDR3L SDRAM 4Gb chip running at 1.35V. Mmm dedicated cache.
«Prev 1 2 3 4 5 6 7 8 Next»
16-07-2020, 09:40:44
Avet
Impressive drive. With a bit of a stretch, you can now go full NVME and skip SATA SSDs completely. Just bunch of spinning rust for backups and you will have the speed for days.Quote
06-08-2020, 08:06:45
fadingfool
It was on sale on Amazon so picked it up and was very impressed. Plugged into a cheap (£10) PCIe card it still out performs the 256GB Samsung PM961 that is on the motherboard. I'll definitely be buying NVMe drives in future (well until I run out of PCIe slots) .Quote
