Super Talent 128GB SATA II SSD
ATTO Disk Benchmark
ATTO Disk Benchmark is another favourite at the OC3D Hq, it seems to be one of the older utilities which is in service but it still helps sort the wheat from the chaff.  ATTO is particularly good for testing SSD performance, all tests were run with the default settings of 0.5KB through 8192KB transfer sizes, with a total length of 256MB.  Key stages of the benchmark are included in the graphs below.
Results Analysis
As with the CrystalDiskMark benchmarks the Super Talent FTM28GX25H puts in a stirling performance when it comes to the Write tests.  It has no problems beating both the OCZ Summit and OCZ Vertex drives in all but one of the Write benchmarks.  The read perfomance is also very close only losing out to both of OCZ’s offerings in the 32k Read test.  I ran this particular test in total 15 times due to the result difference between the drives, convinced that something must be wrong.  I was unable to improve on this test result for some reason.  As with the previous tests, the results of the SSD’s outshine the old mechanical drives by a large margin.
Move along for some PC Mark Vantage results. Â
