ASUS ROG Chimera G703 Gaming Laptop Review
SiSoft Sandra
ASUS ROG G703 Gaming Laptop Review
SiSoft Sandra
The i7-7820 at the centre of the G703 gives performance extremely close to a desktop i7-7700K. Not quite as high, but so near that you wont spot the difference in a blind test.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Next»
26-10-2017, 12:23:48
evilcorp
Great review TTL. Having spent a lot of time with the Alienware 17 with a similar high end spec and then the MSI GT75VR the Chimera seems very interesting.
The cooling system looks very good im glad the Asus has separate cooling fans and heat pipes for both the cpu and gpu. It sound like at 96c the cooling solution is doing a good job of keeping the 7820hk under control. I suspect with better thermal paste and a slight undervolting you could probably get <90c overclocked. The price is about what I would have expected. I just hope that the EU gets 2 years rather than the paltry 1 year asus offers on some of their higher end laptops.
How was the panel? was there any flex in it? Did it look great? How did it sound?Quote
26-10-2017, 13:24:02
VonBlade
Panel looked amazing, no flex (as I mentioned) and it sounded as good as you'd expect a high end laptop to sound.Quote
26-10-2017, 13:39:10
Wraith
330W
Not bad at all for a gaming laptop, very impressed given that it's a desktop GPU. Kudos Asus.Quote
26-10-2017, 13:49:46
AlienALX
I had a ROG laptop once and it was a work of art. Seriously, just massively over engineered in every aspect.Quote
03-11-2017, 13:16:19
fejerm
96C CPU temp brings up a lot of questions. But before this let's consider the previous flagship, the G701VIK. That one had 7820HK CPU too. When running 4.3 GHz even during the most CPU intensive gaming (BF1, ROTTR) it maxed out at 84C with turbo fan. So this brings up the question, why does the Chimera with better cooling have higher CPU temp?
A ) did you run the CPU 4.3 GHz clocked ?
B ) were you gaming or running synthetic tests ?
C ) were you using auto fan or turbo fan? I
If you got 96c in Games with turbo fan and noncpu oc then your review unit is defective and needs a repaste.
However if CPU temp is around 80C running the most CPU intensive games at 4.3 GHz, then the CPU temp is perfectly normal.
Please add this information to the review because it is too important to leave out and can be a deal breaker for people considering this laptop.
I assume you dont test gaming laptops very often, so this was a good experience for the reviewer.Quote
