Cyberpower Hyper Liquid Ultra 7 GTX Ti Review
Published: 17th August 2018 | Source: Cyberpower | Price: £2399 As Reviewed |
No matter how confident you can get at building your own system, whether air or AIO cooled, a watercooled system is always a big step up in skill level and associated worry. If you really want to push the boat out and have a watercooled system which looks as good as any system you've seen at tech shows then you need to go for hard line tubing, which has a further difficulty level to the point that, unless you're a plumber or highly experienced, puts it beyond the reach of most people.
That is where pre-built systems shine the brightest, taking away all that stress and hassle without leaving you looking covetously at demo systems. Cyberpower have a full range of systems available to suit every pocket, and a fulsome customisation suite to allow you to tailor a particular setup to match your own desires. One of the biggest bug bears of pre-built systems was always having to accept whatever the builder had decided was part of that set-up, which usually led to owners being unhappy at one or more elements. The last thing you want when unpacking your hard-saved purchase is to be anything but utterly delighted, and so the customisation ability ensures that you will be completely happy with all elements.
Our review sample today is one of Cyberpower's higher end products, namely the Hyper Liquid Ultra 7 GTX Ti. Based around the eight core Ryzen 7 2700X processor and a nVidia GTX 1080 Ti this promises to handle almost every task you could assign to it, whilst the hard line watercooling ensures that the whole system can run at peak efficiency.
The Cyberpower Hyper Liquid Ultra 7 GTX Ti is available with a whole host of options. The default setup is below and our review sample matches this in a lot of ways although we have, as you can see from the picture above, also got RGB LED strips and fans included. The benefit of the Cyberpower setup is that you can tweak their systems significantly to your own preferences and budget.
- Operating System: Windows 10 Home (64-bit Edition) Perfect for most people with all the core features of Windows 10 including: automatic updates, Cortana and DirectX 12 graphics support (Recovery Disk)
- Today's Special Offers: Bullguard Internet Security 2018 for Windows PC with Game Booster! - 1 year - 3 User Licence
- Case: Cooler Master MasterCase H500P RGB High Air Flow Gaming Case w/ Tempered Glass Side Panel
- Case LED Lighting: None Selected
- Extra Case Fans (Standard, LED, RGB & Corsair iCue): Default Case Fan
- Cyberpower Noise Reduction Technology: None Selected
- CPU (Processor): AMD Ryzen 7 2700X - 8-Core 3.70GHz, 4.35GHz Turbo - 16MB L3 Cache Processor
- CPU Cooling: Cyberpower Hyper Liquid II Medium Rigid Tube Water Cooling Loop (240mm Radiator) - RGB Upgrade
- Coolant for Cyberpower Hyper Liquid II Cooling Kit: High Performance Ultra Pure Clear Distilled Water
- Second Coolant for Cyberpower Hyper Liquid II Cooling Kit (Dual Loop Only): None Selected
- Motherboard: MSI X470 Gaming Pro Carbon AMD X470 Chipset, CrossFire/SLI supported, ATX Mainboard w/ RGB, 4 RAM slots, HD Audio, GbLAN, USB3.0, SATA-III, RAID, 2 x PCIe x16, 1 x PCIe x4, 2 x PCIe x1
- Memory (RAM): 16GB (2x8GB) DDR4/3200mhz Dual Channel Memory (ADATA XPG Sprectrix D80 w/Liquid Cooling)
- Graphics Card (GPU): RGB Watercooled (with EK Block) GeForce® GTX 1080 Ti 11GB Video Card VR READY (Single Card)
- PSU (Power Supply): EVGA 750W SuperNOVA G2 80+ Gold Modular Gaming Power Supply
- M.2 SSD Drive: 500GB (1x500GB) Samsung 970 EVO M.2 PCIe NVMe SSD - 3400MB/s Read & 2300MB/s Write (Single Drive)
- 2nd M.2 SSD Drive: None Selected
- PCI-E SSD: None Selected
- Solid State Drive (SSD): None Selected
- Hard Drive (HDD & SSHD): 2TB Seagate BarraCuda SATA-III 6.0Gb/s 7200RPM Hard Drive (1 Drive)
- Fan Control and Temperature Displays: None Selected
- Internal USB Hub: Built-in USB Ports
- Wired Networking: ONBOARD 10/100/1000 GIGABIT LAN PORT -- As standard on all PCs
- Sound Cards: HIGH DEFINITION ON-BOARD AUDIO
- USB Port and Hub: Built-in USB Ports
- Internet Browser: Microsoft Edge Internet Browser (default with Windows 10)
- Fast Track Service: Standard Processing Time. Estimated Shipping Date: Tuesday, 28/8/2018
- Warranty Service: DESKTOP STANDARD WARRANTY: 3 Year Labour, 2 Year Parts, 6 Month Collect and Return plus Life-Time Technical Support
- Home Installation Service: None Selected
Only things I think I would sort out is the nasty multi coloured fan cable and header cables, but that's 20 mins work at best.
Very clean, nice job.Quote
It sounds like something someone came up with after they drank 10 cans of redbull
