Cyberpower Hyper Liquid Ultra 7 GTX Ti Review
All Lit Up
All Lit Up
The small slivers of RGB lighting on the IO and chipset heatsink sections of the MSI X470 Carbon are absolutely dominated by the combination of LED strip and LED fans at the heart of the Hyper Liquid Ultra 7 GTX Ti. Even the RGB lighting on the DDR4 grabs your attention more easily. You can also see from the wall how bright the lighting is with two 200mm fans in the front and the brightness and placement of the RGB strip within the case mean that the whole area around your system will be represented by your colour choice.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Next»
17-08-2018, 11:54:40
Dicehunter
It sounds like something someone came up with after they drank 10 cans of redbull Quote
17-08-2018, 12:40:26
AlienALX
I really like that. It's clean AF and when lit in white it looks very reserved. Usually CP get a bit carried away into tacky/gaudy territory.
Only things I think I would sort out is the nasty multi coloured fan cable and header cables, but that's 20 mins work at best.
Very clean, nice job.Quote
