Intel NUC 11 Extreme Review - Ultra-Compact High-End Gaming NUC
PCMARK - NUC 11 Extreme VS Pre-Built Systems
Once again, we are comparing Intel's NUC 11 Extreme compare with larger pre-build desktop systems. Like our NUC 11 Extreme sample, PCSpecialist's Quartz Elite R and Lunar Spark systems both contain an Nvidia RTX 3060. So, how well does Intel's vastly smaller NUC compare.
Here are the specifications of all three systems.
 NUC 11 ExtremePCS Quartz Elite RPCS Lunar Spark
CPUIntel i9-11900KBAMD Ryzen 7 5800XIntel i5-11400
Case SizeNUC Compute ElementATXATX
Memory16GB 3200MHz (2x8GB)16GB 3200MHz (2x8GB)8GB 2400MHz (1x 8GB)
GraphicsASUS RTX 3060 DualZotac RTX 3060 AMP White Edition RTX 3060
SSDSabrent Rocket 4 512GB512GB Intel 670p PCIe 3.0256GB PCS SSD
CPU CoolingNUC Compute ElementAIO Liquid CoolerPCS 120mm Air Cooler
PCMARK 10
Intel's NUC 11 Extreme and its i9-11900KB easily outpaces the PSC Lunar Spark and its i5-11400 and sits relatively close to PCSpecialist's Quarts Elite R system with its Ryzen 7 5800X.
The fact that Intel's NUC sits within the same ballpark as PCSpecialist's much larger Quartz Elite R system is huge a positive point for Intel's NUC system. Remember that Intel's NUC 11 Extreme is barely taller than a Mini ITX motherboard. You can't build a mini ITX gaming system this small, which means you cannot fit a liquid-cooled Ryzen 7 5800X within this form factor.
What Intel had created within the NUC 11 Extreme's form factor is impressive. While similarly small Mini ITX cases are available, Intel's NUC barebones systems offer users a level of simplicity that many smaller ITX cases lack. Intel's NUC form factor can also be applied to at-scale deployments, giving it a useful business use case.
