OCUK Tech Labs Chameleon Hardline Review
OcUK Tech Labs Chameleon Hardline Review
Clock Speeds
The Core i7-6700K at the heart of the Chameleon is overclocked up to 4.6GHz on our review sample. Plenty of CPU horsepower for any task you require.
The nVidia GTX 1080 boosts up to 2050MHz but, as you can see if you catch the temperature result before we show you the graph later on, the thermal threshold is most definitely not going to be the limiting factor in any overclock you perform.
OcUK Tech Labs Chameleon Hardline Review Â
