OCUK Ultima Raptor Review
SiSoft Sandra
Published: 27th April 2010 | Source: OCUK | Price: £1199 |
Testing
So with the system fired up and running we installed the standard set of OC3D benchmarks and got to work seeing how well she ran.
Because this is a system that has been pre-overclocked to 4GHz by the Overclockers UK team, our graphs are a little sparser than normal. However after the behemoths that have been the other ones you've seen today I'm sure you'll be pleased.
We'll start with SiSoft Sandra, which tests the calculation abilities of the Ultima Raptor and its included AMD Phenom II X6 1090T. Don't forget that this is a ready to run 4GHz six core system.
The Whetstone and Dhrystone tests give us the capabilities of the system in GigaFLOPS (FLoating point Operations Per Second) and GigaIPS (Instructions Per Second) respectively.
Our Cryptography tests showed a good amount of available bandwidth across the board with only the AES dipping below a GB/s.
If you just want to buy it and use it its perfect.Quote
Top notch review as allways Mr Tom ,Just a quick note tho bottom of the first page there is a spelling mistake btw it says "4gb or ram"Quote
