PC Specialist LS-H01 Review
Up Close - Internals
Up Close Internals
As you'll see below - or indeed above - the red colouring isn't represented perfectly in the following shots. However we'd rather light the internals to show you every detail first and show you the actual colouring later, rather than leave you squinting at the screen.
There is no doubt that wherever you look on the inside of the LS-H01 you're greeted with an aesthetic treat. Every piece of tubing is perfectly routed, exactly the right length, and shows off your choice of Mayhems coolant. Unquestionably the SLI connector is the star of the show here. It's so gorgeous I wanted to marry it. Hell if our review sample came with orange coolant I'd probably have eloped. It is a glorious thing.
PC Specialist LS-H01 Review     PC Specialist LS-H01 Review
Mounting the pump is vital to negate some of the vibrations that can occur and PC Specialist have done a perfect job. It's fixed solidly as you'd need yet there is zero vibration transfer to the 750D. Excellent.
It's almost a shame that the EK GPU blocks are at their most impressive when you look at them from below. We could stare at them for hours. If you've ever tried to decide between a black delrin top and a clear one, go for the clear. Doesn't it look amazing?
Whilst the LS-H01 comes with SLI GTX 980 Tis, the water blocks are designed for the Titan X. Because both nVidia offerings have the same PCB layout it makes sense to use EKs best option, and as a small bonus anyone who only looks into your case will think you have SLI Titan Xs. Cool.
We think few things demonstrate the attention to detail of the PC Specialist builders better than this cable here. Look at all those cable ties and some double-backing to ensure that everything is just so. The rear is almost as impressive as the front.
Actual Colouring
Because lighting the inside ends up washing out the colours slightly, here are the main elements of the water cooling loop with the red looking how it does to the eye, rather than how we have to light it to demonstrate the internals. As you'll see on the next page, the LS-H01 has enough lighting of its own.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
09-05-2016, 11:00:27
Wraith
Nice write up Bryan, and top job PC Specialist for another quality system. I will say this though the thought of a pre filled loop in a £3k+ system in the hands of our gentile courier ninjas would frighten the crap out of me.Quote
09-05-2016, 11:54:24
tinytomlogan
Isnt an issue if its built right with flexible hose.
Back in the day I used to ship systems with 7/16 hose on 1/2 barbs with no clamps or zipties holding the hose on and they all got there fineQuote
09-05-2016, 14:20:28
RobM
whens the video ?
Looks like a nice rig thereQuote
09-05-2016, 16:07:36
notcool
Very nice but when are you going to explain the new awardsQuote
10-05-2016, 07:38:10
noext
gaming benchmark are weird..
http://www.comptoir-hardware.com/ima...h_far_cry4.png
http://www.comptoir-hardware.com/ima...graph_gta5.png
i dont thinks even with massive OC that the 980ti can reach 150fps in GTA VQuote
