PC Specialist Vanquish Arc Midi Review
Up Close
The Vanquish Arc is housed in the attractive Fractal Arc Midi R2 case, which is probably the best small case on the market. It’s well designed and can be thought of as a blank sheet of paper onto which you can draw anything, rather than the more outlandish cases that force you to go down a certain route akin to join the dots.
PC Specialist build quality is fantastic, with all of the cables carefully routed out of sight and tied down neatly.
We like that the choice of parts isn’t only designed to give you the best possible system for the money, but to look great in situ too. The internals are mainly black, with the red of the Maximus VI Hero accented with the white fans and drive cage.
As well as the system, PC Specialist also supply you with everything that you would have if you’d purchased the items separately. This is a fantastic idea as it allows you to add new hardware without having to buy cables and screws that would have otherwise been supplied.
The whole system is extremely well sorted, and there is absolutely nothing to complain about with the build quality and cable routing.
