The PCO Group Intel I7 Gaming PC
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
Â
Â
Â
Â
SuperPI is the benchmark of choice for many overclockers as it’s lightweight to download and can give a quick indication on how good a system is at number crunching. A test of 8 million itterations was performed a total of 5 times with the highest and lowest times removed from the results and an average calculated from the remaining three.
Â
Â
Cinebench 10 is a benchmarking tool based on the powerful 3D software Cinema 4D. The suite uses complex renders to guage the performance of the entire PC system in both single-core and multi-core modes. Testing was performed a total of 5 times with the highest and lowest results being omitted and an average created from the remaining 3 results.
Â
Â
Â
Results Observation
The PC has output some solid numbers though our first set of tests. Multi-threaded benchmarks really shining, showing what the I7 can do with a bit extra oomph behind it. The single threaded SuperPi showing some, while not jaw dropping, competent figures coming in at just under 11 seconds on a 1M test. The Cinebench results looking impressive also, with the multi core test standing out like a sore thumb once again.
