Arctic’s Liquid Freezer II RGB/A-RGB AIOs are now available with 280mm and 420mm models
Arctic’s Liquid Freezer II A-RGB AIOs are now available with 280mm and 420mm radiators
Both of these new coolers use Arctic’s 140mm P-fans, which are designed to deliver high levels of static pressure at low noise levels. These new CPU coolers both support Intel’s new Alder Lake LGA 1700 CPU socket out of the box, requiring no upgrade kit or other add-ons to support Intel’s latest processors.
With price tags of €99.99 and €142.99, Arctic’s 280mm and 420mm A-RGB models are highly affordable when compared to many competitors, giving their support for A-RGB lighting and their larger than average radiator sizes. Strangely, the ARGB and RGB versions of these liquid coolers are priced identically on Arctic’s website.
What follows is Arctic’s Press Release for their new 280mm and 420mm CPU liquid coolers.
Press Release – WATER COOLING WITHOUT COMPROMISE
ARCTIC, one of the leading manufacturers of low-noise PC coolers and components, has added the powerful Liquid Freezer II 280 and Liquid Freezer 420 RGB and A-RGB models to its award-winning AIO range. The multi-compatible water coolers are also equipped for Intel’s new Alder Lake CPUs with LGA1700 sockets. With the efficient PWM-controlled pump, featuring a VRM fan for additional cooling in the socket area, as well as the proven 140 mm P-fans, achieving high static pressure with very low noise, the ARCTIC Liquid Freezer II series clearly sets itself apart from other AIOs and offers plenty of overclocking flexibility.
A maintenance-free water circuit and the integrated cable management, which hides the PWM and RGB cables in the hose sleeves, plus a six-year manufacturer’s warranty underline the high quality and complete the attractive price-performance ratio of the Liquid Freezer II range. The color-capable, effective LED lighting of the fans makes these high-performance coolers the ideal choice for gaming PCs. Optionally, the Liquid Freezer II 280 RGB and Liquid Freezer 420 RGB are also available in a bundle with Arctic’s software-controlled RGB controller.
The Liquid Freezer II 280 A-RGB and Liquid Freezer II 420 A-RGB models offer even more lighting options with individually addressable LEDs for fully customized color display.
Availability
New Liquid Freezer II models are now available in the ARCTIC Webshop and in stores
You can join the discussion on Arctic’s new Liquid Freezer II RGB and ARGB Liquid Coolers on the OC3D Forums.
