ASUS launches their A31 series of PC cases
ASUS’ new A31 PC case is now available to buy
ASUS has just launched a new PC case, and it looks pretty nice. Meet the A31, a new mid-tower PC case from ASUS that supports 360mm liquid cooling solutions and GPUs up to 380mm long. With back-connect motherboard support and solid pricing, this case has the potential to be fairly popular, especially amongst system integrators.
The ASUS A31 is available in two forms. First, there is the standard A31, which ships with no included fans. Next, there is the A31 Plus, which ships with four pre-installed ARGB fans. In the UK, the A31 costs £99.99, making it a great value PC case. The Plus model’s included fans are a single standard 120mm fan and three reverse-blade 120mm fans. The three reverse-blade fans act as intakes at the front/right of the case.
Connectivity-wise, the A31 features one 20 Gbps USB 3.2 Gen 2×2 Type-C port, two USB 3.1 Gen 1 Type-A ports, and a single headphone/microphone jack.
With support for GPUs up to 380mm in length, this case supports GPUs as large as ASUS’ ROG Astral RTX 5090. The top of the case also supports 360mm liquid cooling solutions. Three fans can also be mounted at the base of the case for direct GPU airflow.
Behind this case’s motherboard tray is 34mm of space for cable management. Perfect for ASUS BTF/”hidden-connector” PC builds.
In the UK, the ASUS A31 Plus is available at Overclockers UK and Scan Computers for £99.99. The case is available in both black and white.
You can join the discussion on ASUS’ new A31 PC case on the OC3D Forums.
