ASUS Launches their ROG Strix Helios Chassis for Showcase Builds
The case market is the final frontier of the PC market that ASUS’ ROG brand has yet to occupy, and that is where the ROG Strix Helios steps in, an EATX compatible chassis which offers a robust design, support for large water cooling radiators and more than enough space to accommodate any ROG series component.
The ROG Strix Helios is designed for showpiece systems, offering users integrated RGB lighting, twin tempered glass side panels and removable carry handles which enable users of the case to easily transport their systems to LAN parties or gaming events without much hassle. All LEDs within the Strix Helios are addressable, allowing users of the Helios to adjust their case lighting setup to meet their exacting specifications.
The Strix Helios is designed with ASUS’ other components in mind, featuring support for a top-mounted 360mm radiator to support Ryoujin series liquid coolers and a power supply cut-out to expose the OLED screen that is included in ROG Thor power supplies. Water cooling wise the Helios supports a front mounted 420mm radiator and up to a 360mm on the roof of the enclosure.
As we mentioned before, the Strix Helios is designed to accommodate up to EATX systems with custom water cooling loops and heavy-duty components; all while offering the ability to transport these heavy systems to events. To help achieve this goal, ASUS has integrated a graphics card brace into their case, which enabled up to two graphics cards to be supported, preventing GPU sag.
ASUS has also created their Helios case with an advanced front panel which features RGB controls, USB 3.1 Type-C connectivity and a fan controller. This comes in addition to four USB 3.0 Type-A connections, power/reset switches and headset/microphone audio jacks.
In the UK, ASUS plans to release their ROG Strix Helios chassis for £249.99, with availability coming later this month at Scan, Overclockers UK and other retailers.
You can join the discussion on ASUS’ ROG Strix Helios PC enclosure on the OC3D Forums.
