be quiet upgrades its Light Loop lineup with new IO LCD models
be quiet unveils its Light Loop IO LCD CPU liquid coolers at CES 2026
be quiet is at CES 2026, and they have upgraded their lineup of CPU liquid cooling solutions. This year, be quiet will unleash its new Light Loop IO LCD series, giving users new 240mm and 360mm CPU liquid cooling solutions with RGB lighting and a customisable 2.1-inch LCD display.
be quiet has also taken steps to make the PC building process easier. With their new IO series, be quiet’s liquid coolers now have a single cable that goes from their liquid coolers to the back of your PC case. This cable connects to be quiet’s new IO hub, which then connects to your PC and PSU. This simplifies cable management and makes PC building a little bit easier.
Light Loop IO LCD: Breathtaking performance meets visual brilliance
The centerpiece of be quiet!’s CES line-up is Light Loop IO LCD, a high-performing All-in-One water cooler featuring an advanced IPS display and immersive RGB lighting, designed for overclocked systems. The 2.1-inch high-resolution display with 500 Nits of brightness enables extensive customization, allowing users to display system information (such as CPU and GPU clock speeds, system temperatures, and memory usage), videos, images, or custom presets (such as song titles or a music equalizer).
With three daisy-chained Light Wings LX PWM high-speed fans, a specially designed jet plate and cold plate, and a state-of-the-art pump with progressive IC, Light Loop IO LCD delivers exceptional cooling performance while maintaining whisper-quiet operation. The included IO Controller enables software control via be quiet!’s IO Center for Windows or via IO Center Web on supported browsers, providing full customization of ARGB lighting (including a brand-new Screen Sync mode), fan control, and display content. Light Loop IO LCD will be available in 360mm and 240mm sizes and in two color options: black and white.
– be quiet!
(OC3D be quiet CES 2026 booth tour)
Below you can see be quiet’s new IO hub. This hub can be controlled using be quiet’s new IO Center app for Windows. Alternatively, the be quiet IO Center Web can be used on your preferred browser. This app allows for full RGB lighting customisation, fan control, and LCD display control.
The LCD display on be quiet’s coolers can display system information, play videos, show images, or run custom presets. These presets include a music equaliser, or “song titles” mode. Surrounding RGB lights can also sync with your screen. The screen on this liquid cooler is 2.1 inches in size and operates at up to 500 nits of brightness.
be quiet’s Light Loop IO LCD series will be available later this year in 240mm and 360mm forms and will be available in Black and White.
You can join the discussion on be quiet’s Light Loop LCD CPU liquid cooling solutions on the OC3D Forums.
