Cablemod releases AIO sleeving kits
Have you ever wanted an AIO with custom tubing?
PC builders love to customise their hardware, it is a simple fact of life. People want to create systems that are unique, specific to them, creating a market for a huge range of aftermarket modifications. For years people have sleeved their own PSU cables, painted their cases or even go as far as to physically modify your chassis with power tools and an idea in mind.
Thankfully today it is much easier to create a custom system, with sleeved cables being relatively simple to acquire wither as extensions or full-on replacements, but can the idea be brought to other products?
Today Cablemod has released their new AIO sleeving kits, which are designed to cover the hoses of All-in-one liquid coolers to give PC builders a custom colour scheme. These kits simply sit on top of your AIO's existing hoses and deliver a unique aesthetic.
These AIO sleeving kits are currently available for Corsair Hydro Gen 2 liquid coolers and EVGA CLC and NZXT Kraken AIOs, with black, light blue, light green, red and white colour options.
These new AIO sleeving kits are available to order on Cablemod's own website, though they are also expected to become available at partnered retailers soon.
You can join the discussion on Cablemod's new AIO sleeving kits on the OC3D Forums
«Prev 1 2 Next»
10-08-2017, 17:32:44
Davva2004
I'm guessing you'd have to drain the AIO, remove the tubing, install the sleeves, and then refill and bleed the AIO somehow? That's gonna be a PITA on systems that don't use G1/4 fittings
Edit: I stand corrected, looks like it wraps around the tubes without removing them.Quote
10-08-2017, 18:58:56
Dicehunter
Wouldn't mind getting the red ones for when the new Corsair AIO's release.Quote
11-08-2017, 07:54:34
AlienALX
Would be interested to see if they affect temps.Quote
11-08-2017, 09:24:21
AngryGoldfish
I can't imagine how they'd affect temperatures. Maybe they would, but how?
I like them, but I think they look a little cheap. I think the plain black sleeving that Corsair and NZXT use is the best looking. I also like the thick satin black tubing that EKWB use in their Predator AIO's.Quote
11-08-2017, 09:49:50
AlienALX
I doubt it. And if they did it would probably be a couple of degrees. I've just got an engineer's brain. I always look at things technically first.. Logic..
I did notice the hoses on my old EVGA Hyrbid (with Titan XM) used to get pretty bloody hot. And they had air flowing over them.. Whether insulating would make a difference? hopefully some one like WYP can tell us. It might help, because if insulated the heat is all transferred out through the fins etc or it may shove the temps up.
I don't like them though. They kinda look like granny's old tea cosy.Quote
