Cooler Master launches a new ARGB Vertical GPU Mounting kit
Cooler Master’s new Universal Vertical GPU mounting kit has some neat extras
Vertical GPU mounting has become an incredibly popular option for high-end gaming PCs. After all, high-end GPUs are expensive, so why not display your graphics card in a more visually pleasing way. Cooler Master has just launched a new, universal vertical GPU mounting system for ATX and M-ATX PCs, allowing PC builders to add a vertical GPU mount to their PCs with ease.
This new vertical GPU mount from Cooler Master features some new additions that its predecessors lacked. For starters, they feature a GPU quick release. This makes it much easier to uninstall, maintain, and replace your graphics card. It also feature tool-less adjustability features, allowing users to move their GPU mount up to 65mm horizontally, or up to 30mm towards your case’s side panel.
(GPU Quick Release)
Cooler Master has included one of their ultra-flexible PCIe 4.0 riser cables with their new ARGB vertical GPU mounting kit. This makes this mount compatible with the latest graphics cards, even Nvidia’s mighty RTX 4090.
Within this new vertical GPU mounting kit is a rotatable ARGB lighting element. This can be used to deliver minimal or maximum RGB illumination around your graphics card. This allows users to give their system the look they desire. Non-RGB fans can simply unplug these LEDs if they don’t like the RGB aesthetic.
(Rotatable LED Lighing)
Currently, this vertical GPU mount is only available in Asia, though we expect it to come to Western PC hardware retailers soon. You can learn more about this new vertical GPU mount from Cooler Master on their website.
You can join the discussion on Cooler Master’s new Universal Vertical GPU mount on the OC3D Forums.
