Cooler Master launches their MasterFan SF120M
Cooler Master has officially released their premium MasterFan SF120M series of PC case fans, offering a design that’s designed for pure performance and costs $29.99 in the USA. That’s right; Cooler Master is ready to take on the likes of Noctua in the premium fan market.
The SF120M features a patented anti-vibration motor design that features a dual ball-bearing design for reduced friction and minimised noise output. In addition to this, Cooler Master has used an exclusive sound dampening frame design to lessen vibrations further and to dampen the fan’s noise output further.
With the SF120M, Cooler Master has also used a fan structure which minimises blade flex, reduces the chance of fan breakages and helps to maximise airflow. The fan also uses a detachable PWM cable and offers switches that can define top speeds that range from 1200 RPM to 2000 RPM on the fan directly. Cooler Master’s detachable fan cables will allow users to create multi-fan setups for easier cable management and to use custom braided fan cables. }
More information on these fans is available on Cooler Master’s website.
You can join the discussion on Cooler Master’s Masterfan SF120M fan on the OC3D Forums.
