Cooler Master’s ultra-customisable MasterFrame 600 is now available in the UK and Europe
Cooler Master’s MasterFrame 600 is now available across Europe
Cooler Master has announced that its new MasterFrame 600 PC case is now available across Europe, providing gamers with access to the company’s most modular chassis to date.
Thanks to the open nature of this MasterFrame 600’s design, this PC chassis is a modder’s paradise. Users can remove parts, remount them in new locations, and even create custom components to make their systems unique. With their FreeForm 2.0 design philosophy and replaceable parts, the MasterFrame series is Cooler Master’s platform for the future. This is a future where PC builders can change, adapt, and evolve their cases to suit their changing tastes and needs.
(Picture from Cooler Master’s Computex 2025 Booth)
Silver and Black
The MasterFrame 600 is available in Black and Silver. The silver version ships with ARGB Sickleflow fans, and the Black model ships with Black non-ARGB Mobius series fans. Both cases support Mini ITX, Micro ATX, ATX, XL-ATX, and E-ATX motherboards. In other words, this case supports pretty much all commercially available motherboards. It also supports graphics cards up to 485mm long and ships with a GPU support bracket.
FreeForm 2.0
Using their FreeForm 2.0 “Exo-Structure” design, Cooler Master’s MasterFrame PC cases are incredibly adaptable. This allows users to change the locations of their PC’s motherboard tray, PSU mounts, and other components. Users can also replace the exterior panels of their PCs to give their systems a new look. Over time, this should allow MasterFrame case owners to make huge changes to their systems, both functionally and aesthetically.
Key Features of the MasterFrame 600:
- Supports up to 11 fans and radiators up to 420mm for maximum cooling efficiency
- Integrated GPU support bracket to prevent sag and maintain system integrity
- Fully open-source design with downloadable layout files and modder-friendly documentation
- Built with FreeForm 2.0 for unmatched modularity and creative flexibility
- Durable steel and aluminium construction built to withstand heavy use and time
MasterFrame 600 Pricing
Un Europe, the MasterFrame 600’s MSRP is $199. In the UK, the case is already available through Scan UK for £169.99. Both colour options have launched with the same pricing levels, giving neither model a price advantage.
You can join the discussion on Cooler Master’s MasterFrame 600 becoming available in Europe on the OC3D Forums.
