Published: 9 June 2017 |
Source:
Corsair |
Author:
Corsair showcase their first 360mm AIO liquid cooler
Corsair has recently showcased their latest prototype AIO liquid coolers, which are designed to offer PC builders quieter offerings with several design improvements over previous generation hardware.
Silence is key with these new AIO coolers, coming with Corsair’s new ML-series of silence optimised fans and a new pump design that will offer more efficient fluid flow and reduced noise output.
One of the most interesting additions to Corsair’s AIO liquid cooling lineup will be their new 360mm radiator designs, which will allow PC builders to easily cool any modern CPU with silent fan profiles and low load temperatures.
With Intel’s X299 CPUs coming with up to 18 overclockable cores, the need for high-end cooling solutions has never been greater, though right now it is unclear whether or not Corsair’s new AIO designs can support AMD’s massive TR4 Threadripper socket/mounting system.
You can join the discussion on Corsair’s first 360mm H-series liquid cooler on the OC3D Forums.
