Corsair’s Colossal 9000D RGB Airflow PC case is now available
Corsair’s insane 9000D PC case is now available to purchase
If size matters to you, Corsair has a PC case for you. The Corsair iCUE LINK 9000D RGB Airflow is now available, succeeding the company’s 1000D as the ultimate case for liquid cooling enthusiasts. This PC case can house up to two 480mm liquid cooling radiators at its front and many more in other locations.
This case has the size and scale to give users incredible levels of flexibility. Want thick liquid cooling radiators with push-pull fans? The 9000D is large enough to accommodate that. Want a large graphics card and an EATX motherboard? Easy! With its Infinirail mounting system, it is incredibly easy to install fans and liquid cooling radiators inside your system.
Included in this case is a Corsair iCUE LINK system hub, which can control this case’s front I/O and up to 23 other iCUE LINK devices. This case’s massive front I/O also sports a wealth of options with four USB 3.2 Gen 1 Type-A ports, two USB 3.2 Gen 2 Type-C ports, and separate 3.5mm audio in/out jacks.
Storage-wise, this case supports up to five 3.5-inch drives and up to six 2.5 inch drives. The case also has plenty of space for dual PSU setups.
With an asking price of £499.99, this case is incredibly expensive. That said, this case this case is huge, heavy, and well-built. We saw this case in person at Computex 2024, and it is a sight to behold. If you want a HUGE PC and have the available funds to fill it, the 9000D is a case worthy of consideration.
You can join the discussion on Corsair’s 9000D PC case on the OC3D Forums.
