Customisable TRYX LUCA L70 PC cases leak
TRYX’s E-ATX LUCA L70 case has been revealed
Ahead of the company’s appearance at Computex 2025, a new PC case from TRYX has leaked onto the web. This PC case from TRYX is called the LUCA L70, and it is highly customisable.
TRYX is well-known for its Panorama series of CPU coolers (review here), and its newest product is its Panorama SE series liquid cooling solution. Both coolers feature curved AMOLED screens, giving users a panoramic visual experience. Their new LUCA L70 case complements this design with its 270-degree panoramic window, giving users an unobstructed view into the case.
(Images from cfd.com)
Users of the LUCA L70 can customise their case to suit their needs. The case’s motherboard tray can be moved and removed from the case when necessary. This simplifies the PC building process, and allows users to use top-mounted, and bottom-mounted PSU configurations.
The overall cooling layout of this case depends on your preferred airflow layout. With a bottom-mounted PSU, users can mount up to a 420mm liquid cooling radiator at the top of the case. With a top-mounted PSU, up to three 120mm fans can point directly at your graphics card. This is ideal for gaming systems, where your GPU is likely your most power-hungry component.
Note that this case features an anodised aluminium frame and 4mm thick tempered glass panels. The case is also raised 4cm above your desk surface to enable strong airflow at the base of the chassis.
This PC case has an estimated price of 36,990 yen, which converts to around £195. We expect to see this case in person later this month at Computex 2025. If it is present at TRYX’s booth, you can expect us to report on it again.
You can join the discussion on TRYX’s upcoming LUCA L70 PC case on the OC3D Forums.
