EKWB Releases New P Series Liquid Cooling Kits
EK has just launched their new P series of water cooling kits, giving PC builders everything they need to set up a CPU only water cooling loop in a single package.
This water cooling kit is designed to cool all modern CPU sockets an are made to be expandable into a CPU+GPU water cooling loop with ease, thanks to EK bundling their strong Revo D5 Pump/reservoir and coming in a wide range of Radiator size options.
These kits will come with EK’s own Vardar Series fans, offering great performance and a high static pressure with little noise, EK’s Supremacy EVO CPU Water block, EK’s XRES 140 Revo D5 Pump/Reservoir and EK’s own compression fittings for easy installation.
These water cooling kits will be available with 360mm, 280mm and 240mm radiators, making these kits suitable for a wide of PC cases.
All the parts used in these kits are using standardized water cooling fittings, allowing the parts to be easily upgraded or replaced in the future if the user need to.
You can join the discussion on EK’s new P Series of Water Cooling Kits on the OC3D Forums.
